is there a Problem by using I2C and PWM at the same time? When I use the Pwm_Init function of your library, the I2c_Read() and I2c_Write() trigger an internal error (“I2C Error: .\src\config_parser.c, 434: Context Corruption”).
What could that be? Library-Version is “toradexcelibraries_2.2-20180516”.
Without init PWM I2C-communication works fine, but I need that for actual project.
