Hello! When deploying applications using Visual Studio Code with the Toradex extension, there are several important steps to keep in mind:
Container Image Preparation: Ensure that your container image is correctly built and tagged before deployment. This is crucial for a smooth deployment process. You can find more details on this here.
Production Deployment Steps:
- Use the “run-container-torizon-release” task in VS Code to build and run the release container on your target device. This step is essential for testing your application in a production-like environment. More information can be found here.
- Execute the “create-production-image” task in VS Code to build a release container image and push it to your configured container registry. This ensures your application is ready for deployment across multiple devices. Further guidance is available here.
Key Considerations:
- Be aware that any changes made after the container starts will be lost once the container exits. This is a standard behavior of containerized applications. More details are available here.
- You can run multiple containers from the same image, which is useful for scaling your application. More information is provided here.
To troubleshoot any issues you encounter:
- Review the output of the VS Code tasks to understand the steps being executed. This can help identify where the process might be failing. More troubleshooting tips are available here.
- Attempt to manually reproduce the failing step to pinpoint the issue.
- Check your container registry settings in the
.vscode/settings.jsonfile to ensure they are correctly configured.
If you need more specific guidance on any part of this deployment process, feel free to ask!
