Problem setting LCD resolution to 800x480
I have a setup using Colibri iMX6 where I can successfully run:
fw_setenv vidargs video=mxcfb0:dev=lcd,800x480M@60,if=RGB666 video=mxcfb1:off fbmem=8M
to change resolution permanently.
Now I have plugged in an iMX7D 1 GB, and the command doesn’t work with that.
Do you have an idea how I get it to work ?
I have included a dmesg.[link text][1]log
[1]: https://share.toradex.com/khncrf734epan9f?direct
J
hi @JohnnyPaycheck
The uboot command for setting resolution for iMX7 is different, since it is a different SOC. This is the correct command:
setenv vidargs video='mxsfb:800x480M-16@60'
Please check this site for further Information about resolution and timings in Linux.
Best regards, Jaski
Thanks, Jaski ! That was quick - and it works :slight_smile:
Perfect that it works. You are welcome.
I have one additional problem: The touchscreen calibration that runs at startup doesn’t remember the calibration - and it doesn’t take effect, so my touchscreen is “mirrored”: the mouse pointer moves in opposite direction as touch !
Could you ask a new question, please? Thanks.
