Problem rebuilding TorizonCore with evaluation containers
I downloaded TorizonCore with evaluation containers 6.1.0-devel-202212+build.4.container for Verdin iMX8M Mini and I installed with Toradex Easy Installer.
It starts, and everything is ok.
Accessing with ssh I copied the file /var/sota/storage/docker-compose/docker-compose.yml (as I read here this is the file that describes which containers should be launched at the boot).
Then I read documentation for torizoncore-builder on how to generate a custom image.
My first attempt is:
  • starting from TorizonCore 6.1.0-devel-202212+build.4 (without evaluation containers)
  • use torizoncore-builder to generate a custom image which is the TorizonCore with evaluation containers, using the proper docker-compose.yml to bundle the desired containers (see here).
I setup a working environment for torizoncore-builder, but when I launch torizoncore-builder bundle ... I see that portainer/portainer-ce and torizon/weston-vivante are pulled properly.
But torizon/chromium cannot be pulled with the following error:
Fetching container image torizon/chromium@sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d
sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d: Pulli  sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d: Pulli  sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d: Pulling from torizon/chromium
  Error: no matching manifest for linux/amd64 in the manifest list entries
Stopping DIND container
Error: container images download failed: 404 Client Error for https://127.0.0.1:22376/v1.40/images/torizon/chromium%40sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d/json: Not Found ("no such image: torizon/chromium@sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d: No such image: torizon/chromium@sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d")
And if I look to dockerhub I don’t see any torizon/chromium with the above sha.
Where is my mistake?
Greetings @vix,
The issue is actually shown in the error logs you provided, specifically this line:
You must have not specified the platform for the container images. This means for images that provide multiple architectures, like torizon/chromium, Docker will attempt to pull the architecture that matches the system. However, the torizon/chromium image has no “linux/amd64” options so it fails to find any.
If you check the schema for the build command here: TorizonCore Builder Tool “build” command | Toradex Developer Center
You’ll see there’s a property to specify the exact platform for container images to be pulled.
This is actually misleading on Docker Hub. The digest shown on the Web UI isn’t the same digest of the actual image.
