I am having trouble flashing a TK1 image on an Ixora board using the procedure: Flashing Embedded Linux to Tegra Modules
When I run setupdate, I get:
Apalis TK1 # run setupdate
MMC: no card present
** Bad device mmc 1 **
Card did not respond to voltage select!
** Bad device mmc 2 **
The booloader for the TK1 is version U-Boot 2015.04 (Jun 28 2016 - 12:50:18)
Following the same procedure, I’ve successfully flashed a T30, using the same same SD card and the same Ixora carrier.
Any ideas?
