Earlier was using V2.7 BSP and able to dial 3G/4G donlge using PPP .But after updating BSP to 2.8b6.183-20190331 , PPP dialing is not success. After dialing getting failed from ISP side but the same dongle is working with V2.7 with same configurations.
Using Huawei 4G Dongle (E3372h) In both OS Versions (V2.7 & 2.8) its able to detect the dongle. USB id for dongle is 12d1:157c .Then using usb_modswitch to convert to modem mode.
Connection log is attached for both OS versions.link text
Could you provide the hardware version of your module? Which carrier board are you using?
Have you done any changes to the Software? If yes, please share these changes?
How are you dialing in? Could you share any commands or scripts used?
We bought the same USB Dongle as you and tested it on Bsp 2.8b6.
Usually if you switch to the new Huawei Mode, then you get a ethernet interface which you can access using a Webbrowser and change the configuration. The Ethernet interface can be used to connect to the internet.
Alternatively you can apply the following command to switch the modem to the correct mode:
Building with normal cross compilation method.
export PATH and CC
configure, make, make install to prefix directory then transfer to SOM .
but its asking for wvstream as dependency. Compiling the wvstream is pointing to openssl and so on.
Sory for the delay.Was not having OE setup. So i arranged all the required things and successfully compiled new image with wvdial.
With wvdial also am geting same issue what i faced with pppd.
vendor:0x12d1 product:0x157c
usb_modeswitch -v 12d1 -p 157c -P 1506 -M 55534243123456780000000000000011062000000100000000000000000000
lsusb command is showing that device is turned to modem mode
Tried with wvdialconf for default configuration, but it was not detecting. So given manual configuration.
Details are included in the log file with steps i tried. link text
Please see the attached log files link text
Unfortunately its still not working.
Am totally clueless on this issue.
Also noticed another point.Once we connect datacard with SoM, the same is not on PC also (Linux PC using pppd dialing). Again we need to use huaewei datacard software(windows PC) and select the network type as shown in uploaded screenshot
We will try to get one of this dongle and try this on Vybrid module. Our tests on iMX6 were successful. We will come back next week to you. Thanks very much for your patience.
