Dear Support Team,
We are using below registry setting for power state changing between normal and user idle to let our Colibri iMX6 based product LCD turning off when no operation.
HKLM\System\CurrentControlSet\Control\Power\Timeouts
"BattUserIdle" = dword:0000xxxx (seconds)
"BattSystemidle" = dword: 00000001
"BattSuspend" = dword: 00000000
"ACSuspend" = dword: 00000000
"ACSystemidle" = dword: 00000001
"ACUserIdle"=dword:0000xxxx (seconds)
it works but we met another issue for the power state changing notification to our application, because we still need some processing when power state changing - both from normal to user idle and user idle to normal.
our application is developed under vcsharp, could you help advise how to catch this notification from application?
Thanks a lot!
