Port conflict for moses
I am trying to run VScode extension on Linux mint, but i keep getting the following error.
"The terminal process “/home/fahad/.vscode/extensions/toradex.torizon-early-access-1.6.5/moses-linux/moses ‘–port’, ‘5000’” terminated with exit code: 255.
it seems like there is a port conflict for port 5000, both moses and docker-registry use the same port.
how do i change port for moses.
Hi @fahads ,
One possible cause for this error message could be due to OpenSSL 1.1 not being installed on the system. Can you try downloading and installing libssl1.1:
wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.17_amd64.deb
sudo apt install ./libssl1.1_1.1.1f-1ubuntu2.17_amd64.deb
After running the commands above check if the VSCode extension runs correctly.
EDIT: Updated link. If this new link eventually fails try going to Index of /ubuntu/pool/main/o/openssl and download the lib manually.
Lucas Akira
Hi @fahads !
Do you have any updates regarding this topic?
Did you manage to solve it?
yes, it worked by installing openssl v1.1
Hi @fahads !
Thanks for the feedback!
Hi Toradex,
I’m trying the “openssl” solution for the same error message, but it seems the deb file is renamed. Any better solution?
$ wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.16_amd64.deb
--2023-02-09 10:53:24--  http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.16_amd64.deb
Resolving security.ubuntu.com (security.ubuntu.com)... 185.125.190.39, 185.125.190.36, 91.189.91.39, ...
Connecting to security.ubuntu.com (security.ubuntu.com)|185.125.190.39|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2023-02-09 10:53:25 ERROR 404: Not Found.
Hi @jeffreyx ,
You’re right, the link is outdated, can you try this one instead:
I’ll update my original answer with this new link as well.
Try that and see if it works for you.
Lucas Akira
