Custom Plymouth Animation Setup for Toradex Reference Images
Plymouth Configuration for Custom Animations
For creating custom Plymouth splash animations on Toradex Reference Images with Yocto Project, you’ll need to properly configure your Plymouth theme files (1).
Basic Plymouth Theme Structure
The recommended approach is to create a custom layer following the established pattern (1):
recipes-core/plymouth/plymouth_%.bbappend
(1)
Your .bbappend file should include (1):
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
SRC_URI += " \
file://torizonlogo-white.png \
file://spinner.plymouth \
EXTRA_OECONF += "--with-runtimedir=/run"
do_install:append () {
install -m 0644 ${WORKDIR}/torizonlogo-white.png ${D}${datadir}/plymouth/themes/spinner/watermark.png
install -m 0644 ${WORKDIR}/spinner.plymouth ${D}${datadir}/plymouth/themes/spinner/spinner.plymouth
(1)
Animation Timing Considerations
For animation functionality, Plymouth provides several built-in modules. The documentation shows that Plymouth supports various themes including the spinner theme (1). However, for custom animations with timing functions like Plymouth.SetTimeout() and Plymouth.SetUpdateFunction(), you may need to ensure your script theme is properly configured.
Build Integration
To include Plymouth in your Reference Image, add this to your conf/local.conf (1):
CORE_IMAGE_EXTRA_INSTALL += "plymouth"
(1)
Directory Structure
Your custom layer should follow this structure (1):
├── conf
│ └── layer.conf
├── COPYING.MIT
├── README
└── recipes-core
└── plymouth
├── files
│ ├── spinner.plymouth
└── plymouth_%.bbappend
(1)
Building and Deployment
After configuration, build your image (1):
$ bitbake tdx-reference-multimedia-image
(1)
You can verify Plymouth installation using (1):
$ bitbake -e tdx-reference-multimedia-image | grep plymouth
(1)
Important Notes
Starting from BSP 6, Linux Kernel splash screen support has been dropped, making Plymouth the recommended solution (2). Plymouth runs very early in the boot process and provides graphical boot animation while the boot process happens in the background (1).
For animation timing issues you’re experiencing, ensure your Plymouth script theme is correctly configured and that the animation functions are properly implemented within the Plymouth scripting framework.
