To address the permission error you’re encountering when the ‘torizon’ user inside your container tries to access the Docker socket, you’ll need to ensure that this user is part of the ‘docker’ group. This group membership is essential for accessing the Docker daemon via the socket.
Here’s how you can resolve this:
Modify the Dockerfile or Docker Compose: Ensure that the ‘torizon’ user inside your container is added to the ‘docker’ group. You can achieve this by including a command in your Dockerfile or Docker Compose file to add the user to the group.
For example, in your Dockerfile, you can add:
RUN usermod -aG docker torizonThis command appends the ‘torizon’ user to the ‘docker’ group.
Rebuild and Restart the Container: After making changes to the Dockerfile, rebuild your container image and restart the container to apply the updates.
Verify Group Membership: Once the container is running, you can verify that the ‘torizon’ user is part of the ‘docker’ group by executing:
docker exec -it <container_name> groups torizonThis should list ‘docker’ among the groups for the ‘torizon’ user.
By ensuring the ‘torizon’ user is part of the ‘docker’ group, you should be able to execute Docker commands without encountering permission errors. This setup aligns with best practices for managing permissions in Torizon containers, allowing non-root users to perform necessary operations securely.
I hope this helps! If you have any more questions, feel free to ask.
Imx8x Torizon 5.7.2 to 6.3 Upgrade Journey - permissions on /etc/docker wrong on update.
