PCA9555 I2C I/O Expander under Linux
I want to use the PCA9555 I2C I/O expander under Linux.
I try to configure the Linux kernel for PCA9555 support (pca953x driver), but the option “Device drivers->GPIO Support” is missing.
Where did you get kernel sources from?
Which modules are you using?
I get the kernel from Toradex with git, following the document Build Linux
Image: V2.6
Kernel git branch: toradex_imx_3.14.52_1.1.0_ga
Module: Colibri iMX6.
Can you share commands and outputs you’ve used to setup toolchain and kernel?
# download kernel
$ git clone -b toradex_imx_3.14.52_1.1.0_ga git://git.toradex.com/linux-toradex.git
# run script to set environment & check vars ARCH/PATH
$ source ./environment_arm.sh
$ echo $ARCH
$ echo $PATH
# change dir name
$ mv linux-toradex kernel-linux-toradex-3_14_52
$ cd kernel-linux-toradex-3_14_52
$ make nconfig
nconfig shows lots of options to configure the linux kernel, but the option “Device Drivers->GPIO Support” is missing.
you’re missing:
make colibri_imx6_defconfig
you are right, thank you.
