Override Yocto ALTERNATIVE_PRIORITY with bbappend
is it possible to override the ALTERNATIVE_PRIORITY with a bbappend file?
I have tried it with the following recipe as systemd_%.bbappend without success.
SUMMARY = "Remap resolv.conf from connman back to systemd-resolv"
LICENSE = "CLOSED"
inherit update-alternatives
ALTERNATIVE_PRIORITY = "200"
ALTERNATIVE_${PN} = "${@bb.utils.contains('PACKAGECONFIG', 'resolved', 'resolv-conf', '', d)}"
ALTERNATIVE_TARGET[resolv-conf] = "${@bb.utils.contains('DISTRO_FEATURES','systemd','${sysconfdir}/resolv-conf.systemd','',d)}"
ALTERNATIVE_LINK_NAME[resolv-conf] = "${@bb.utils.contains('DISTRO_FEATURES','systemd','${sysconfdir}/resolv.conf','',d)}"
do_install_append() {
I want to link /etc/resolv.conf to systemd by default.
Martin
Hi @gandi ,
Thanks for reaching out to Toradex.
We are looking at your question and get back to you as soon as possible.
Kevin
Hi @gandi ,
I would expect that a systemd_%.bbappend with the following content would do what you want to do:
# increase priority from 50 to 200
ALTERNATIVE_PRIORITY[resolv-conf] = "200"
The ALTERNATIVE_PRIORITY[resolv-conf] ?= “50” setting takes precedence over your systemd global ALTERNATIVE_PRIORITY = “200”.
Overwritting ALTERNATIVE_${PN} the way you do it removes all the other alternatives the systemd recipe defines. Is this something you really want / need?
Max
Hi @max.tx ,
thank you for your answer, it works now.
My target is to use systemd-network for eth0 and eth1, so I blacklisted these interfaces without the connman configuration. I want to keep connman for future use with bluetooth or wifi. My filesytem is readonly and /etc is overlayed with a folder on a separate partition.
But now I have the problem that /etc/machine-id is empty after bootup (fresh install) and the dhcp client wont start. The overlay is applied in fstab.
Do you have any idea how to fix this behaviour?
Thank you
Martin
Hi @gandi !
As you are overlayfs-ing the /etc folder, it is possible that the interaction of the overlayfs with the machine-id service is rendering an empty /etc/machine-id.
Could you please use systemd-analyze dump to output systemd’s steps and find when the overlayfs and the machine-id are bring performed?
