I follow bitbake method to build Toradex Easy Installer images from below link.
High performance, low power Embedded Computing Systems | Toradex Developer Center
Build goes fine when I use local machine or my laptop’s VM but fails on Server with below log:
neeraj.verma@arm1irv:~/oe-core/build$ bitbake -k console-tdx-image
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Error, you have an invalid character (@) in your COREBASE directory path. Please move the installation to a directory which doesn't include any @ characters.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Only difference I can see in local machine versus server is number of cores (server has 16 cores, and local machine has 4 cores).
Can someone please help me to identify issue?
