I am trying to install Python3 and OpenCV 2 with Tegra support on my Apalis TK1 system running the L4T image that is provided via Easy Installer.
I have verified that Python3 is installed, and I have also installed version 6.5 of the Cuda Toolkit. However, when I run the cmake command for OpenCV, I do not see any reference to it detecting and validating Cuda support is enabled.
The cmake command I run is:
cmake -D CMAKE_BUILD_TYPE=RELEASE
-D CMAKE_INSTALL_PREFIX=/usr/local
-D WITH_CUDA=ON
-D ENABLE_FAST_MATH=1
-D CUDA_FAST_MATH=1
-D CUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-6.5
-D WITH_CUBLAS=1
-D INSTALL_PYTHON_EXAMPLES=ON
-D OPENCV_EXTRA_MODULES_PATH=…/…/opencv_contrib-3.1.0/modules
-D BUILD_EXAMPLES=ON …
The results I get back are:
– GUI:
– QT: NO
– GTK+ 2.x: YES (ver 2.24.23)
– GThread : YES (ver 2.40.2)
– GtkGlExt: NO
– OpenGL support: NO
– VTK support: NO
– Media I/O:
– ZLib: /usr/lib/arm-linux-gnueabihf/libz.so (ver 1.2.8)
– JPEG: /usr/lib/arm-linux-gnueabihf/libjpeg.so (ver )
– WEBP: build (ver 0.3.1)
– PNG: /usr/lib/arm-linux-gnueabihf/libpng.so (ver 1.2.50)
– TIFF: /usr/lib/arm-linux-gnueabihf/libtiff.so (ver 42 - 4.0.3)
– JPEG 2000: /usr/lib/arm-linux-gnueabihf/libjasper.so (ver 1.900.1)
– OpenEXR: build (ver 1.7.1)
– GDAL: NO
– Video I/O:
– DC1394 1.x: NO
– DC1394 2.x: NO
– FFMPEG: YES
– codec: YES (ver 54.35.1)
– format: YES (ver 54.20.4)
– util: YES (ver 52.3.0)
– swscale: YES (ver 2.1.1)
– resample: NO
– gentoo-style: YES
– GStreamer: NO
– OpenNI: NO
– OpenNI PrimeSensor Modules: NO
– OpenNI2: NO
– PvAPI: NO
– GigEVisionSDK: NO
– UniCap: NO
– UniCap ucil: NO
– V4L/V4L2: Using libv4l1 (ver 1.0.1) / libv4l2 (ver 1.0.1)
– XIMEA: NO
– Xine: NO
– gPhoto2: NO
– Parallel framework: pthreads
– Other third-party libraries:
– Use IPP: NO
– Use VA: NO
– Use Intel VA-API/OpenCL: NO
– Use Eigen: YES (ver 3.2.0)
– Use Cuda: NO
– Use OpenCL: YES
– Use custom HAL: NO
– OpenCL:
– Version: dynamic
– Include path: /home/ubuntu/opencv-3.1.0/3rdparty/include/opencl/1.2
– Use AMDFFT: NO
– Use AMDBLAS: NO
– Python 2:
– Interpreter: /usr/bin/python2.7 (ver 2.7.6)
– Libraries: NO
– numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.8.2)
– packages path: lib/python2.7/dist-packages
– Python 3:
– Interpreter: /usr/bin/python3.4 (ver 3.4.3)
– Libraries: NO
– numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.8.2)
– packages path: lib/python3.4/dist-packages
– Python (for build): /usr/bin/python2.7
– Java:
– ant: NO
– JNI: NO
– Java wrappers: NO
– Java tests: NO
– Matlab: Matlab not found or implicitly disabled
– Documentation:
– Doxygen: NO
– PlantUML: NO
– Tests and samples:
– Tests: YES
– Performance tests: YES
– C/C++ Examples: YES
– Install path: /usr/local
– cvconfig.h is in: /home/ubuntu/opencv-3.1.0/build
Could anyone please advise as to what I may be doing wrong.
Many thanks in advance.
