Hi, I am building a lockbox to update containers on our device, which has three containers (weston-vivante, cog and custom app). It behaves as expected, but I recognized that it takes 6 mins to load cog image and 4 mins to load weston-vivannte image. I’m wondering whether there are ways to reduce the update time since we only want to update the app images/containers while keeping using the same weston-vivante and cog images/container.
Please see the below aktualizer logs for details. Thanks!
-- Logs begin at Thu 1970-01-01 00:00:06 UTC. --
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: Certificate issuer: CN=ota-devices-CA
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: Certificate valid from: Dec 2 23:45:47 2022 GMT until: Nov 8 23:45:47 2121 GMT
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: initializing...
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: using TCP port 8850.
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: Offline Updates are enabled
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: starting thread.
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: listening to connections...
Dec 08 02:42:32 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: SendDeviceDataComplete
Dec 08 02:52:40 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: sending device data to Torizon OTA.
Dec 08 02:52:40 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: SendDeviceDataComplete
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: fetchMetaOffUpd() called with source_path: "/media/usb1/update"
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Current version for ECU ID: 918af54786776b6feed7cccb0d3b9626a9b28e22de5584fb6a249a4a572b865e is unknown
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: New updates found in Director metadata. Checking Image repo metadata...
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: 1 new update found in both Director and Image repo metadata.
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: UpdateCheckComplete, Result - Updates available
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Update available. Acquiring the update lock...
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Image already fetched; skipping fetching
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: DownloadTargetComplete, Result - Success
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: AllDownloadsComplete, Result - Success
Dec 08 02:53:10 colibri-imx8x-06787895 aktualizr-torizon[950]: Waiting for Secondaries to connect to start installation...
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: No update to install on Primary
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: InstallStarted
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/etc/sota/conf.d/100-offline-updates.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/usr/lib/sota/conf.d/20-sota-device-cred.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/usr/lib/sota/conf.d/30-rollback.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/usr/lib/sota/conf.d/40-hardware-id.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/usr/lib/sota/conf.d/50-secondaries.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Reading config: "/usr/lib/sota/conf.d/60-polling-interval.toml"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Use existing SQL storage: "/var/sota/sql.db"
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: docker-compose file matches expected digest
Dec 08 02:53:12 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading metadata from tarball: /media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/68377c13050f5fe2b20959534e5dc6639431e070bdbac875bfef1310705727f2.tar
Dec 08 02:55:50 colibri-imx8x-06787895 aktualizr-torizon[1391]: Loaded image: cifengfang/cxldnabit-release:digest_sha256_68377c13050f5fe2b20959534e5dc6639431e070bdbac875bfef1310705727f2
Dec 08 02:55:50 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading of "/media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/68377c13050f5fe2b20959534e5dc6639431e070bdbac875bfef1310705727f2.tar" finished, code: 0, status: success
Dec 08 02:55:50 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading metadata from tarball: /media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/29659a376ad6647c8ee903cb2f2cf8a84f3890a1f68e95632e084e6723cbe2bf.tar
Dec 08 02:57:40 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: sending device data to Torizon OTA.
Dec 08 03:01:41 colibri-imx8x-06787895 aktualizr-torizon[1422]: Loaded image: therndgroup/kiosk-mode-browser-vivante-cog:digest_sha256_29659a376ad6647c8ee903cb2f2cf8a84f3890a1f68e95632e084e6723cbe2bf
Dec 08 03:01:42 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading of "/media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/29659a376ad6647c8ee903cb2f2cf8a84f3890a1f68e95632e084e6723cbe2bf.tar" finished, code: 0, status: success
Dec 08 03:01:42 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading metadata from tarball: /media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/b39bd723e554a95522bd6774796d6af7cac7cf4960e1c142b9a6f45e62691f45.tar
Dec 08 03:05:04 colibri-imx8x-06787895 aktualizr-torizon[1477]: Loaded image: torizon/weston-vivante:digest_sha256_b39bd723e554a95522bd6774796d6af7cac7cf4960e1c142b9a6f45e62691f45
Dec 08 03:05:04 colibri-imx8x-06787895 aktualizr-torizon[950]: Loading of "/media/usb1/update/images/a6e85f5678c75cc4b691c2b7f001a23374c4e7fe603889e81451ad97ac7f64d5.images/b39bd723e554a95522bd6774796d6af7cac7cf4960e1c142b9a6f45e62691f45.tar" finished, code: 0, status: success
Dec 08 03:05:04 colibri-imx8x-06787895 aktualizr-torizon[950]: Updating containers via docker-compose
Dec 08 03:05:04 colibri-imx8x-06787895 aktualizr-torizon[950]: Running docker-compose down
Dec 08 03:05:04 colibri-imx8x-06787895 aktualizr-torizon[950]: Running command: /usr/bin/docker-compose --file /var/sota/storage/docker-compose/docker-compose.yml -p torizon down
Dec 08 03:05:10 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_web ...
Dec 08 03:05:10 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_kiosk ...
Dec 08 03:05:10 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_weston ...
Dec 08 03:05:12 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_web ... done
Dec 08 03:05:13 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_kiosk ... done
Dec 08 03:05:13 colibri-imx8x-06787895 aktualizr-torizon[1506]: Stopping cxldnabit_weston ... done
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_web ...
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_kiosk ...
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_weston ...
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_weston ... done
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_web ... done
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[1506]: Removing cxldnabit_kiosk ... done
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[950]: Running docker-compose up
Dec 08 03:05:14 colibri-imx8x-06787895 aktualizr-torizon[950]: Running command: /usr/bin/docker-compose --file /var/sota/storage/docker-compose/docker-compose.yml.tmp -p torizon up --detach --remove-orphans
Dec 08 03:05:18 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_weston ...
Dec 08 03:05:20 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_weston ... done
Dec 08 03:05:20 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_kiosk ...
Dec 08 03:05:23 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_kiosk ... done
Dec 08 03:05:23 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_web ...
Dec 08 03:05:25 colibri-imx8x-06787895 aktualizr-torizon[1581]: Creating cxldnabit_web ... done
Dec 08 03:05:26 colibri-imx8x-06787895 aktualizr-torizon[950]: Removing not used containers, networks and images
Dec 08 03:05:26 colibri-imx8x-06787895 aktualizr-torizon[950]: Running command: docker system prune -a --force
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[1746]: Deleted Images:
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[1746]: untagged: cifengfang/cxldnabit-release:digest_sha256_68377c13050f5fe2b20959534e5dc6639431e070bdbac875bfef1310705727f2
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[1746]: untagged: torizon/weston-vivante:2.5.1
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[1746]: Total reclaimed space: 0B
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: InstallTargetComplete, Result - Success
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: AllInstallsComplete, Result - OK
Dec 08 03:05:27 colibri-imx8x-06787895 aktualizr-torizon[950]: Update install completed. Releasing the update lock...
Dec 08 03:05:28 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: SendDeviceDataComplete
Dec 08 03:05:31 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: sending device data to Torizon OTA.
Dec 08 03:05:32 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: SendDeviceDataComplete
Dec 08 03:07:40 colibri-imx8x-06787895 aktualizr-torizon[950]: PROXY: sending device data to Torizon OTA.
Dec 08 03:07:40 colibri-imx8x-06787895 aktualizr-torizon[950]: Event: SendDeviceDataComplete
