Greetings @xAnouk,
First of all what version of TorizonCore are you running here? Also what module is this, Verdin i.MX8M Mini or Plus?
I sometimes get the error: 'Fatal:
[Errno 2] No such file or directory: '/dev/verdin-adc1'
Regarding this error is it actually the case that there is no /dev/verdin-adc1 or is this error message misleading and this does exist? Also how often would you say this happens?
With regards to your application/container are you manually launching it after the device has booted? Or is it automatically launching on boot?
