We are chasing down several issues starting up on WinCE with an Apalis T30. One of the problems is a crash in our application, which I have a support case about. This is a slightly different case.
We have a fixture that turns our device on an off, then tests for our application life. I do not know if this particular problem start after we added a custom splash screen or not, but about one out of every 200 times that we power on the device, the device displays just the splash screen, and never launches our application. The splash screen just stays there. I have the serial debug turned on, and the full output is below.
Toradex Windows CE 8.0 IMAGE 2.0 for Tegra Built Feb 6 2017
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
L2 cache enabled
MainMemoryEndAddress adjusted from 0x86000000 to 0x9C000000
Main Phys Mem: 0x80000000:0x9BFFFFFF
Carveout Phys: 0x9C000000:0x9FFFFFFF
Cold boot selected
WatchDog Enabled (5000 ms)
SMP: Active CPUs = 4
Extended Mem : 0xA0000000:0xFFEFFFFF
Chip Id: 0x30 (Handheld SOC) Major: 0x1 Minor: 0x3 SKU: 0xb1
NVRM Initialized shmoo database
PllClocks(Mhz): X=1300, M=800, C=600, P=408, A=24.576
SysClocks(Mhz): CPU=1300, AVP=240, SysBus=240, Mem=400, EMem=800
GraphicClocks(Mhz): Host=106, 3D=133, 2D=133, Epp=133, Mpe=133, Vde=408
Loading FlashFileSystem(eMMC)...
Done FlashFileSystem(eMMC)(1)
Loading Audio...Done
Loading Serial4(UART_D)...Done Serial4(0)
Loading Serial2(UART_B)...Done Serial2(0)
Loading Serial3(UART_C)...Done Serial3(0)
Loading SDIO(SDIO3)...Done(2)
Loading SDIO(SDIO1)...Done(3)
Loading PCIe...PCIE: port 0: link down, aborting
PCIE: port 1: link down, aborting
PCIE: port 2: link up in 0 us
Done
Loading USBFunction(Port1)...Done
RNDISFN:: MTU Default: [8064] bytes.
RNDISFN:: Max OUT transfer: [8192] bytes.
RNDISFN:: ThreadPriority [109].
RNDISFN:: USFN [DOES NOT HAVE] DMA capabilityRNDISFN:: Host MAC = 80-00-60-0F-E8-00.
RNDISFN:: Device MAC = 82-00-60-0F-E8-00.
RndisFn!ReadConfigurationValues: InternetSharing enabled [0]
RndisFn:: Host MAC afer registry consideration: [80 00 60 0F E8 00]
Bus:Device:Function: VendorID,DeviceID
0:0:0: 0x10de,0xe1c Virtual P2P to 1
0:1:0: 0x10de,0xe1d Virtual P2P to 2
0:2:0: 0x10de,0xe1d Virtual P2P to 3
3:0:0: 0x8086,0x157b
Loading I21x Ethernet...Done
Loading USBHost(Port2)...PCIe: Slot Clock Request Change (0x0)
Done
Loading USBHost(Port3)...Done
Loading DisplayDriver...Done(30)
Set LCD to 1024x600 (58Hz)
Set CRT to 1024x768 (60Hz)
Loading Keyboard/MouseDriver...Done
UnfdMutiTchDrv 2.0 loading...done
SoftRTC enabled
RTC Time restored (19.06.2017 15:41:33)
MultiTchHwAdapt loading...done
