We just bought a Verdin imx8mp with a Mallow Carrier board and I am trying to run some example code from the Torizon-samples library to familiarize myself with the concept of multiple container.
Unfortunately, when I run docker-compose up -d with the grafana example, it seems to be running but only a black screen with a mouse open on the display.
I am using WSL 1.2.5.0 on Windows 11. And Docker Client version 24.0.5.
This example was originally designed for TorizonCore 5. I guess it has not been updated yet to work properly for TorizonCore 6. I assume you’re on a TorizonCore 6 correct?
That said I was able to get it working again with some simple changes. After you copy the example source code to your device you want to make the following changes:
Edit your docker-compose.override.yml such that it looks like this:
# this override brings up Grafana on a local display
version: "2.4"
services:
weston:
environment:
- ACCEPT_FSL_EULA=1
container_name: weston
image: torizon/weston-vivante:3
command: --tty=/dev/tty7
# Required to get udev events from host udevd via netlink
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- 'c 4:0 rmw'
# ... for tty7
- 'c 4:7 rmw'
# ... for /dev/input devices
- 'c 13:* rmw'
# ... for /dev/dri devices
- 'c 226:* rmw'
# ... for /dev/galcore device on i.MX8
- 'c 199:* rmw'
kiosk:
container_name: kiosk
environment:
- MACHINE
image: torizon/chromium:3
command: --window-mode http://grafana:3000
security_opt:
- seccomp:unconfined
networks:
- frontend
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /var/run/dbus
target: /var/run/dbus
- type: bind
source: /dev/galcore
target: /dev/galcore
depends_on:
- weston
- grafana
- influxdb
shm_size: '256mb'
- 'c 199:* rmw'
With this once I ran docker-compose up -d I was able to see the Grafana UI on my local HDMI display. I will bring this up with our team internally and see if we can update this example.
Are you sure you copied everything correctly and re-built everything from scratch for the example? This is all the modifications I made to the source and it works for me to show the Grafana UI. I did this on TorizonCore 6.3.0 with a Verdin i.MX8M Plus so it should be the same for you.
In your case could you check if any containers are not running and if so check the logs for these containers.
EDIT: Also actually I just checked, and the original unmodified source works fine as well for showing the Grafana UI. Though it’s a a little buggy since the original source wasn’t designed for TorizonCore 6 as I said earlier. Either way though I have something showing on my local display, so I’m not really sure what’s happening on your setup. Did you also make sure to stop any previously running containers before starting the demo containers?
