Not able to load custom built colibri iMX6ULL yocto image to Toradex easy installer
Hello community,
I have successfully built the Yocto source with MACHINE ?= “colibri-imx6ull” and I have extracted the tezi tar file.
I have put the device in recovery mode and also I am able to install the images which are present on toradex server.
The question is how can I flash my custom generated Yocto images using Toradex Installer. I am unable to load the custom image to the installer.
Do we need to modify the “Feeds” to fetch the local images? is there any guide for this one?
Thanks!
below is the version of the hardware which I am using:
Colibri iMX6ULL v1.1 WB 512MB
Carrier: Aster v1.1B
Thanks for the quick response. Will try this and update you
That worked, I am now able to load the image via Toradex easy installer
Thanks!
