I am not able to boot via USB today… and seeing strange issue says unable to enumerate USB device, whereas same usb works from linux after boot.
Could you please suggest what could be wrong here?
U-Boot 2016.11-1.8.0+g07edca0bb8 (Oct 19 2018 - 13:34:21 +0000)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 38C
Reset cause: POR
DRAM: 512 MiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7S/D
Model: Toradex Colibri iMX7D
Serial Downloader recovery mode, using sdp command
Net: FEC0
Error: FEC0 address not set.
SDP: initialize...
SDP: handle requests...
Downloading file of size 21374744 to 0x82100000... done
Downloading file of size 300 to 0x82000000... done
Jumping to header at 0x82000000
Header Tag is not a IMX image
## Loading kernel from FIT Image at 82100000 ...
Using 'config@imx7d-emmc' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000dc
Data Size: 5308472 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 910fc4bfe6325ca943e1af0824a15957
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x826101fc
Data Size: 15929344 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: bf0a406d6fa572c48f601023ca980bd2
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@imx7d-emmc' fdt subimage
Description: Colibri iMX7 Dual 1GB eMMC Device Tree
Type: Flat Device Tree
Data Start: 0x83557184
Data Size: 45372 Bytes = 44.3 KiB
Architecture: ARM
Hash algo: md5
Hash value: b34140d2c5400aef8309a51bb7486030
Booting using the fdt blob at 0x83557184
Loading Kernel Image ... OK
Loading Device Tree to 8fff1000, end 8ffff13b ... OK
Starting kernel ...
[ 0.349874] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00 :00:00:00:00:00
[ 0.365929] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
Running /etc/rc.local...
Colibri-iMX7_ToradexEasyInstaller_1.8-20181019
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
/ # [ 2.030537] usb usb1-port1: cannot reset (err = -32)
[ 2.035548] usb usb1-port1: cannot reset (err = -32)
[ 2.041812] usb usb1-port1: cannot reset (err = -32)
[ 2.046809] usb usb1-port1: cannot reset (err = -32)
[ 2.051829] usb usb1-port1: cannot reset (err = -32)
[ 2.056794] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2.063405] usb usb1-port1: cannot reset (err = -32)
[ 2.069562] usb usb1-port1: cannot reset (err = -32)
[ 2.074576] usb usb1-port1: cannot reset (err = -32)
[ 2.079560] usb usb1-port1: cannot reset (err = -32)
[ 2.084567] usb usb1-port1: cannot reset (err = -32)
[ 2.089533] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2.096123] usb usb1-port1: cannot reset (err = -32)
[ 2.101134] usb usb1-port1: cannot reset (err = -32)
[ 2.106127] usb usb1-port1: cannot reset (err = -32)
[ 2.111171] usb usb1-port1: cannot reset (err = -32)
[ 2.116215] usb usb1-port1: cannot reset (err = -32)
[ 2.121228] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2.127815] usb usb1-port1: cannot reset (err = -32)
[ 2.132842] usb usb1-port1: cannot reset (err = -32)
[ 2.137868] usb usb1-port1: cannot reset (err = -32)
[ 2.142916] usb usb1-port1: cannot reset (err = -32)
[ 2.147927] usb usb1-port1: cannot reset (err = -32)
[ 2.152936] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 2.159514] usb usb1-port1: unable to enumerate USB device
