Hello @Sebtombs,
If you are using Torizon OS with Docker available, we recommend that you do this in a container. If your concern is hardware access, we have many guides on the topic and it is always possible to run containers with the --privileged
in development.
That being said, if you really don’t want to use containers in your initial tests, an alternative to nohup would be to setup a SystemD service to run your application and start the service.
Here is a basic example of what the service file (/etc/systemd/system/myapp.service
) might look like:
[Unit]
Description=My Application Service
[Service]
Type=simple
ExecStart=/home/torizon/myapp myargs
[Install]
WantedBy=multi-user.target
After creating this file, enable and start your service with:
sudo systemctl enable myapp.service # only needed if you want the application to auto-start at boot
sudo systemctl start myapp.service
Bruno
