I did the following:
- Comnnect power ethernet keyboard+mouse
- Run step1,2,3,4 - all is OK
- Reboot the board
- board leds are on no HDMI no ethernet
Could you please specify what you did on that steps or provide links to them?
The steps i did was following Toradex Quickstart, i fail after step 6:
I download the “TorizonCore with evaluation containers”, get IP address,
bring up the putty - no answer
reboot the boiard - no ethernet blank screen
it looks like the PMIC on board not working after download otherwize the Ethernet leds blinked
see snapshot of the board
HI Alex,
Sorry I forget to ntroduce my activity, I am from Hailo company, the project is to integrate our AI solution in your SOM, hopefully both companies will have buiseness together,
Thanks for your answer, I embedded my answers
Thanks,
Avi
Could you connect Ixora debug UART to your pc and collect logs there?
https://developer.toradex.com/getting-started/module-1-from-the-box-to-the-shell/unboxing-and-setup-cables-ixora-torizon#step-2
That does not look like valid console output. Can you try capturing the same when running the Toradex Easy Installer via USB recovery again?
