After changing some splashscreen parameters, the iMX7-Colibbri module no longer displays the bootloader menu. Also in Recovery mode the menu is no longer available. What can I do?
Output RS232:
BootLoader Configuration:
C) Clear Flash Registry
X) Enter CommandPrompt Mode
D) Download image to RAM now
F) Download image to FLASH now
L) Launch existing flash resident image now
Enter your selection: x
Config List:
mac: Ethernet MAC Address
ip: IP Config
* boot: Boot Config
ser: Serial Port Config
gpio: GPIOs Config
hw: HW Version
* dbg: Debug Config
* ss: SplashScreen Config
pex: Processor Extensions
* part: Partition Config
mem: Memory Config
>set ss
ss.fileaddr: 0x0 (FlashAddress with SplashScreen Data)
ss.filesize: 0 (Size of SplashScreen Data)
ss.enable: 0 (Enable SplashScreen)
ss.dbginfo: 1 (Enable DebugInfos)
ss.res: 0x0 (Reserved Flags)
ss.width: 640 (Display Width)
ss.height: 480 (Display Height)
ss.bpp: 16 (BitsPerPixel)
ss.ldds: 18 (LCD Lines Used)
ss.type: 1 (Display Type (0=Passive, 1=Active))
ss.color: 1 (0=Mono, 1=Color)
ss.dual: 0 (0=SinglePanel, 1=DualPanel)
ss.overlay: 0 (Overlay Enable)
ss.dpc: 0 (Double Pixel Clock)
ss.pcp: 0 (Pixel Clock Polarity)
ss.oep: 1 (Output Enable Polarity)
ss.hsp: 0 (Horizontal Sync Polarity)
ss.vsp: 0 (Vertical Sync Polarity)
ss.bs: 5 (LCD Buffer Strength)
ss.pclk: 33000000 (PixelClock (in Hz))
ss.hsw: 1 (Horizontal Sync Width)
ss.vsw: 1 (Vertical Sync Width)
ss.blw: 10 (Begin of Line Width)
ss.elw: 40 (End of Line Width)
ss.bfw: 5 (Begin of Frame Width)
ss.efw: 5 (End of Frame Width)
ss.acb: 0 (AC Bias Frequency)
ss.disp_gpio: 140 (Display On/Off Gpio)
ss.bl_gpio: 141 (BackLight On/Off Gpio)
ss.dispondelay: 0 (Display On Delay (ms))
ss.disp_pol: 1 (Display On/Off polarity)
ss.bl_pol: 1 (BackLight On/Off polarity)
ss.pcddiv: 1 (Enable Pixel Clock PreDivider)
ss.res: 0x1F80 (Reserved Flags)
ss.fbaddr: 0x0 (Phys FrameBuffer,Palette and Descr Address (0=Auto))
ss.edidaddr: 0x0 (i2c address of the EDID EEPROM (0..0x7f))
ss.edidenable: 0 (enable read from EDID EEPROM)
>ss.enable=1
Invalid Command
>set ss.enable=1
>save ss
Finding configblock...
Writing 5 sector(s) of bootargs data from sector 1792.
>Toradex Bootloader 1.0b4 for iMX7 Built Jul 20 2017
Reset cause: Power-up sequence
Reset cause: Booting from recovery mode
Overriding config block settings. Setting Delay to 30s and [SPACE] for bootloader entry
