I’m trying to load Toradex Easy installer but I have the message “No Matching usb device found” when I launch recovery-windows.bat.
I entered recovery mode from bootloader with commande ‘boot from usb’ and ‘reboot’. I try 2 different cables connected to USB OTG on colibri board, but the message is the same ?
Am I doing Something wrong ? Below the console output.
config file
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
-> vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
no matching USB device found
Appuyez sur une touche pour continuer...
I tested with a 1.1 (new samples) too, it is not working also. I’m trying to boot Toradex Easy Installer, but I need to go to recovery mode, and when I did it with bootloader, my computer does not recognize it when I launch recovery-windows.bat.
@germano.tx
I did not find solution for now unfortunately.
I’m using Windows 10. I don’t see an additionnal HID device in device manager. I can see the green light ON (near USB OTG) on the colibri board when I connect the cable to the computer but nothing else.
