No matching manifest for linux/arm64/v8 in the manifest when building default c++ console App
I solved the issue. In the setting of Docker desktop under General there is a check box “Use containerd for pulling and storing images” When this box is checked you will get the “a * no matching manifest for linux/arm64/v8 in the manifest list entries” error. I unchecked it and everything worked again. I think this got checked when I upgraded docker desktop
