Verdin iMX8MP Q 2GB V1.0B
Dahlia Carrier Board 1.0
Verdin DSI to HDMI Adapter V1.0B
Linux BSP 5.2.0 / 5.5.0-devel
Hi Toradex Support,
yesterday I tried to setup a Verdin i.MX8MP with dahlia and the DSI-to-HDMI adapter, but I’m not able to get an output on 3 HDMI (FullHD) monitors.
The SOM came with BSP 5.2.0, I rebuilt the image, flashed with bmap-tool and tested with 5.5.0-devel (multimedia image), but no luck either.
The lt8912 dtbo is activated in /boot/overlays.txt. At first the verdin-dev dtb was loaded, I changed the board name to dahlia, but that didn’t change much.
Weston starts fine and seems to be running, so no issue on this part.
I guess something in the devicetree is not completely ok, because I get the following error messages:
[ 1.161918] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 1.168934] imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 1.179142] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[ 1.187427] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 1.903392] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 1.910400] imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
Complete journal → journal_12112021.log (1.2 MB)uboot_12112021.log (10.3 KB)
Any ideas what might be going wrong here?
Thanks in advance & best regards,
Peter
