Hello.
This is my first toradex board and i having a throuble with hdmi display.
I loaded Linux with LXDE (3.0b3.118) using Easy installer (through VNC)
Connecting via UART1 i can see linux kernel starting, but no signal on HDMI connector, even during the u-boot starting or if i run the “xstart” command.
I have a Benq display (1920x1080@60 resolution) connected with hdmi-to-VGA port adapter from the Toradex kit.
Are you sure about that as we only officially released Linux console images:
Or did you install something via CI feed?
using Easy installer (through VNC) Connecting via UART1 i can see linux kernel starting,
Including full textual debug output thereof may be helpful in the future.
You mean startx I guess.
You mean you hooked up the HDMI to DVI adapter to the DVI to VGA adapter and expect this to work?
Unfortunately, it is really an HDMI to DVI-D adapter and a DVI-A to VGA one which basically leads to nothing at all if hooked together, sorry (;-p). If you would want to drive an analogue VGA panel from the Ixora’s HDMI you would really need an active HDMI to analogue VGA converter.
