I have adapted the CAN demo project (from the current library) in order to address the iMX7 onboard CAN module. Can1.RX = SODIMM_90 and Can1.TX = SODIMM_92. The wiring on the Eval. Board (see “Colibri Evaluation Board Datasheet” chapter 3.9.1.4.2 CAN TX / RX (X38)) I have done. When I run the program (1. CAN Transmit), I always get the message “CAN Transmit error”. The changes in the code can be seen here:
int wmain(int argc, wchar_t *argv[])
HANDLE hCan = NULL;
BOOL isSelectionDone = FALSE;
INT selectedOption;
BOOL returnValue = FALSE;
DWORD bitRate;
DWORD busStatus;
wprintf(L"Toradex CAN demo\r\n");
// 1. Initialize CAN without affecting hardware registers
hCan = Imx7Can_Init(L"CAN1"); // Internal CAN
if (hCan == NULL)
printf("Error in CAN initialization\r\n");
// Define CAN-Pins and bitrate
uIo ioRx = COLIBRI_PIN(90);
uIo ioTx = COLIBRI_PIN(92);
bitRate = 250000;
returnValue = Imx7Can_SetConfigInt(hCan, L"ioTx", ioTx.GenericDefinition, StoreVolatile))
returnValue = Imx7Can_SetConfigInt(hCan, L"ioRx", ioRx.GenericDefinition, StoreVolatile))
returnValue = Imx7Can_SetConfigInt(hCan, L"BitRateHz", bitRate, StoreVolatile))
returnValue = Imx7Can_SetConfigString(hCan, L"Implementation", L"FlexCAN", StoreVolatile); // use Vybrid internal CAN controller
returnValue = Imx7Can_SetConfigString(hCan, L"FrameFormat", L"standard", StoreVolatile); // Set FrameFormat
returnValue = Imx7Can_SetConfigString(hCan, L"FilterRemote", L"none", StoreVolatile); //
returnValue = Imx7Can_SetConfigString(hCan, L"RtrFormat", L"data", StoreVolatile); //
returnValue = Imx7Can_SetConfigInt(hCan, L"FilterID", 0x00, StoreVolatile); //
returnValue = Imx7Can_SetConfigInt(hCan, L"FilterMask", 0x00, StoreVolatile); //
do
printf("\nOptions:\n");
printf("1. CAN Transmit 2. CAN Receive 3. Quit\n\n");
printf("Choose the option and press Enter key: ");
scanf_s("%d", &selectedOption);
printf("\n");
/// Enter only if there is only one character entered from key board.
switch (selectedOption)
case 1:
/// CAN Transmit
CanTxProcess(hCan);
break;
case 2:
/// CAN Receive
CanRxProcess(hCan);
break;
case 3:
/// Quits the demo
isSelectionDone = TRUE;
break;
default:
printf("Invalid entry, try again!\n\n");
} while (!isSelectionDone);
/// 6. Deinit CAN channel
Imx7Can_Deinit(hCan);
return(TRUE);
Do you have any suggestions for me? Thanks in advance.
