I started from:
repo init -u Index of /toradex-bsp-platform.git -b 64928bb263c89f3e445b239467742444988fa49c -m default.xml
And for Linux:
devtool modify virtual/kernel
Of course NFS is enabled in Kernel.
Like I said, It works fine under BSP 5 but I need this version to have accelerated firmware.
It’s really a matter of network, if I install a rootfs in flash and set my envir on it, system boot.
But I have no network.
I checked lot of thing but I cant find the problem with ethernet.
Now I’m confused. You said "I used this link to build Linux/Uboot for Apalis-Tk1Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center" but building just a kernel does not require a repo init. So could you please explain how exactly you built your version of kernel? And please use a verbose branch name as it listed in the mentioned article.
