Newest IMX95 boards isp not supported by Torizon OS 7
We received a new Verdin imx95 board and it seems like the ISP on this board is a newer revision (B0 ISP) than what is supported by the newest Torizon OS 7 images (A0 ISP) for the neoisp.ko.
For Torizon OS is there a version that supports the newer isp? Maybe a development version?
Based on the available documentation, I can confirm that Verdin iMX95 support was introduced in Torizon OS 7.3.0(1)(2) and continues through 7.4.0(1)(3) and 7.5.0(4). However, the documentation does not contain specific information about ISP silicon revisions (A0 vs B0) or the neoisp.ko driver compatibility with different hardware revisions.
What I Can Confirm
The Verdin iMX95 specifications indicate it includes an “Integrated ISP”(5), and camera support is available through CSI interfaces with device tree overlays like verdin-imx95_ov5640_overlay.dtbo(6).
Recommended Next Steps
Since the documentation doesn’t address the specific B0 ISP revision compatibility issue you’re experiencing:
  1. Check your exact Torizon OS version - Run tdx-info on your device to confirm which build you’re running
  2. Verify your hardware revision - The Verdin iMX95 is listed as a “sample product” intended for evaluation and development(4)(1), so hardware revisions may vary
For ISP driver compatibility with newer silicon revisions, I recommend:
  • Visiting the Toradex Community and searching for discussions about iMX95 ISP revisions
  • Visiting Toradex GitHub to check for any patches or updates related to the neoisp driver
The most recent quarterly release available in the documentation is Torizon OS 7.5.0(4), which added support for Aquila iMX95 but doesn’t specifically mention ISP revision updates for Verdin iMX95.
Greetings @mbcel,
Perhaps try the Walnascar versions for the iMX95 modules listed here: Download Links | Toradex Developer Center
These are experimental, but they use a newer version of the NXP BSP. So perhaps these have the B0 support you are looking for.
In the future with Torizon 8 the latest version of the NXP BSP based on Yocto Wrynose will be used.
