NetworkManager missing wwan plugins in yocto project
Hi Toradex,
I have included the NetworkManager and removed the ConnMan in yocto project by adding below lines in local.conf file.
Remove connman
MAGE_INSTALL_remove = ” connman”
IMAGE_INSTALL_remove = ” connman-client”
IMAGE_INSTALL_remove = ” connman-gnome”
Add NetworkManager
IMAGE_INSTALL_append = ” networkmanager ”
IMAGE_INSTALL_append = ” modemmanager”
I want to use NetworkManager and ModemManager for modem auto connection. But this is not happening because of missing wwan plug in NetworkManager.
Networkmanager-wwan plugin was missing in final image. Log messages are attached for your reference.
Please help on this.
Thank you
Can you please post more details on software version you are using?
Also which modem are you trying to connect and interface you are using?
What are the sequence of steps you are following ?
Please also share the output of below commands
mmcli -m 0
nmcli c
check below article for more information
link text
It is for Torizon but same can be used if you have custom image with network manager and modemmanager.
Ritesh Kumar
Q: Can you please post more details on software version you are using?
Reply: NetworkManager version – > 1.22.10,
ModemManager version – > 1.12.12,
Kernel version → 5.4.77
Q:Also which modem are you trying to connect and interface you are using?
Reply: Quectel EC25-E
Reply:
1.Identifying the wwan interface is managed or not.
root@apalis-imx6:~# nmcli d
DEVICE TYPE STATE CONNECTION
eth1 ethernet connected Wired connection 1
eth2 ethernet unavailable –
can0 can unmanaged –
can1 can unmanaged –
eth0 ethernet unmanaged –
usb0 ethernet unmanaged –
lo loopback unmanaged –
wwan0 wwan unmanaged –
root@apalis-imx6:~# nmcli -p
eth1: connected to Wired connection 1
	"Microchip LAN7500"
	ethernet (smsc75xx), 00:1E:C0:E0:89:FD, hw, mtu 1500
	ip4 default
	inet4 192.168.126.223/22
	route4 0.0.0.0/0
	route4 192.168.124.0/22
	inet6 fe80::7473:5bc3:5e0c:1bfb/64
	route6 fe80::/64
	route6 ff00::/8
eth2: unavailable
	"Microchip SMSC9512/9514"
	ethernet (smsc95xx), 00:1E:C0:E1:09:7D, hw, mtu 1500
wwan0: unavailable
	"Quectel EC25"
	wwan (qmi_wwan), CA:94:10:9D:E4:CA, plugin missing, hw, mtu 1500
2.As you can see wwan0 is showing as unmanaged and plug-in is missing,so i have run a
  command("nmcli dev set wwan0 managed yes") to set as managed one.
3.Now wwan interface is showing as unavailable.
eth2    ethernet  unavailable  --
wwan0   wwan      unavailable  --
can0    can       unmanaged    --
can1    can       unmanaged    --
eth0    ethernet  unmanaged    --
usb0    ethernet  unmanaged    --
lo      loopback  unmanaged    --
root@apalis-imx6:~# nmcli con add type gsm  con-name Modem ifname wwan0 apn airtelgprs.com
Warning: There is another connection with the name 'Modem'. Reference the connection by its uuid 'a6f15d26-06c3-4409-ac56-012c035f193f'
Connection 'Modem' (a6f15d26-06c3-4409-ac56-012c035f193f) successfully added.
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~# cat /etc/NetworkManager/system-connections/
Modem-a6f15d26-06c3-4409-ac56-012c035f193f.nmconnection  cell1
Modem.nmconnection
root@apalis-imx6:~# cat /etc/NetworkManager/system-connections/Modem-a6f15d26-06c3-4409-ac56-012c035f193f.nmconnection
[connection]
id=Modem
uuid=a6f15d26-06c3-4409-ac56-012c035f193f
type=gsm
interface-name=wwan0
permissions=
[gsm]
apn=airtelgprs.com
[ipv4]
dns-search=
method=auto
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
[proxy]
NAME                UUID                                  TYPE      DEVICE
Wired connection 1  977d1334-9847-382d-b222-97576edbe592  ethernet  eth1
Modem               1862ec1c-3987-4bee-ab37-a15a3caea24a  gsm       --
Modem               a6f15d26-06c3-4409-ac56-012c035f193f  gsm       --
Wired connection 2  1bcc27b2-2e81-3e7f-822c-be806b287235  ethernet  --
Q:Please also share the output of below commands
mmcli -m 0
nmcli c
Reply:
root@apalis-imx6:~# mmcli -m 0
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: ba3997d4bf1e6db67a476314710c02cfb3f58eb7
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EC25EFAR06A08M4G
| carrier config: default
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 860548045586564
System | device: /sys/devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.1/1-1.1.2
| drivers: option1, qmi_wwan
| plugin: Quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at), wwan0 (net),
| ttyUSB1 (gps), ttyUSB3 (at)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: gsm
| signal quality: 100% (recent)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-5, eutran-7, eutran-8, eutran-20, eutran-38, eutran-40,
| eutran-41
| current: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-41
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 860548045586564
| operator id: 40449
| operator name: airtel
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
Reply:
wwan0   wwan      unmanaged    --
	"Microchip LAN7500"
	ip4 default
	route4 0.0.0.0/0
	route6 fe80::/64
	route6 ff00::/8
eth2: unavailable
wwan0: unavailable
	"Quectel EC25"
[connection]
id=Modem
type=gsm
permissions=
[gsm]
apn=airtelgprs.com
[ipv4]
dns-search=
method=auto
[ipv6]
dns-search=
method=auto
[proxy]
mmcli -m 0
nmcli c
Reply:
	   |         h/w revision: 10000
	   |               plugin: Quectel
	   |                state: registered
	   |          power state: on
	   |          access tech: gsm
	   |                       eutran-41
	   |                       eutran-41
	   |          operator id: 40449
	   |         registration: home
What is the debug output you get whenever you connect your modem?
Hi @shreyas.
Thanks for the information, we are trying to reproduce the issue, allow us some time to get back to you
Hi @sahil.tx ,
Any update on this issue.
Thank you
Hi Narayanaswamyn,
This requires you to add support for modem for networkmanager as this is not by default enable from network manager recipe.
One can try to add same as below
through local.conf add below lines
PACKAGECONFIG_append_pn-networkmanager = " modemmanager ppp"
Alternatively create bbappend file for networkmanger recipe and patch your changes.
You can take reference from below recipe which is for our Torizon OS
Please check section 5.1.5 in yocto refrence mannual for more information
https://www.yoctoproject.org/docs/1.6/dev-manual/dev-manual.html
Ritesh kumar
