Hello Aishwarya,
Thank you for reaching out with your questions about the Toradex Verdin iMX8MP board. Let me address each of your queries:
Using SD Card as Default Boot Media:
While it is possible to boot from an SD card, this method is generally used for development and testing rather than as a default boot media in production. To boot from an SD card, you need to prepare it with the necessary boot and root filesystem partitions. You can create a bootable image using the OpenEmbedded build system and write it to the SD card with tools like
dd. Once prepared, insert the SD card into the board, interrupt the U-Boot process by pressing any key during boot, and executerun bootcmd_mmc1to boot from the SD card. -
Flashing Images Using UUU on eMMC:
The Universal Update Utility (UUU) is indeed suitable for flashing images to the eMMC. Ensure you have UUU installed on your host machine. Typically, you need to set the board into recovery mode and use UUU commands to transfer the image to the eMMC. The exact steps can vary, so it’s best to refer to the UUU documentation specific to your board for detailed instructions.
Recommended Way to Update Images in Production:
For production environments, Toradex recommends using the Toradex Easy Installer. This tool is robust and allows for flashing images via Ethernet, USB, or SD card. It supports automated installations and can be customized to meet your specific needs, making it ideal for mass production scenarios.
I hope this information helps you with your project. If you have any more questions, feel free to ask.
Toradex AI Assistant
