Hi @drew.tx and team,
You recommended using the following as ways to read the device information:
/proc/device-tree/serial-number
/proc/device-tree/toradex,board-rev
/proc/device-tree/toradex,product-id1
Of course I need to map these into my container and it seemed better not to mount the whole device-tree directory. However, the run command uses commas to separate parameters and I cannot figure out how to map the above devices as the commas in the filename break the command.
I have resolved the issue by creating a symbolic link, which is a reasonable solution but it is a pain to modify Torizon for something like this. Do these files need commas in the names? Could they just be removed?
All suggestions very welcome.
Ed
Hi @edwaugh I’m not sure what command you are issuing that uses commas. I am able to run the following:
$ docker run -v /proc/device-tree/toradex,board-rev:/tmp/board-rev debian:bullseye cat /tmp/board-rev
Note that I did not map it into /proc/devicetree
since that is actually a symlink on the host so it makes it more complicated.
Can you share the specific command you are trying to run?
Drew
Hi Drew,
Thanks for your response, actually I didn’t try it from the command line just from the extension. I used the same target as source and when I change the target to be something without a comma it seems to work fine:
Hi @edwaugh
I reported this back to the dev team and they will take a look. Details are here.
In the meantime, you should be able to create the volume specification of the individual file as long as the container-side name does not contain the comma. The host side of the volume can contain that character.
