hello,
i got the following message from the kernel log during boot:
[ 5.142119] mmc1: error -110 whilst initialising SDIO card
[ 5.229801] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 5.240977] mmc1: error -22 whilst initialising SDIO card
the message is repeated constantly.
i could although find no wifi or bt device with “ifconfig -a” or “hciconfig -a” .
what’s wrong?
here is also the entire boot log:
U-Boot 2016.11-2.8.5+g02735f4004 (Dec 28 2018 - 06:10:28 +0000)
CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 45C
Reset cause: POR
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.1A, Serial# 06388218
Net: FEC0
Booting from NAND...
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd1 (name "mtd=4", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 10/4, WL threshold: 4096, image sequence number: 2099907239
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
No size specified -> Using max size (5426192)
Read 5426192 bytes from volume kernel to 81000000
No size specified -> Using max size (38979)
Read 38979 bytes from volume dtb to 82100000
Kernel image @ 0x81000000 [ 0x000000 - 0x52cc10 ]
## Flattened Device Tree blob at 82100000
Booting using the fdt blob at 0x82100000
Using Device Tree in place at 82100000, end 8210c842
Updating MTD partitions...
Starting kernel ...
[ 0.000000] Linux version 4.9.144-2.8.5+g5758a8e648a3 (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP Fri Dec 28 06:15:14 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Toradex Colibri iMX6ULL 512MB on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @97b8f000 s25804 r8192 d23348 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 376192K/524288K available (7168K kernel code, 386K rwdata, 2204K rodata, 1024K init, 376K bss, 17024K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80800000 (8160 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c60820 ( 387 kB)
[ 0.000000] .bss : 0x80c62000 - 0x80cc0188 ( 377 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000017] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000056] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.003567] Console: colour dummy device 80x30
[ 0.004868] console [tty1] enabled
[ 0.004937] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.005046] pid_max: default: 32768 minimum: 301
[ 0.005294] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005370] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.006859] CPU: Testing write buffer coherency: ok
[ 0.007545] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.010723] Brought up 1 CPUs
[ 0.010806] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[ 0.010865] CPU: All CPU(s) started in SVC mode.
[ 0.012475] devtmpfs: initialized
[ 0.037011] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.037824] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.037960] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.048175] pinctrl core: initialized pinctrl subsystem
[ 0.050800] NET: Registered protocol family 16
[ 0.064082] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.067142] cpuidle: using governor menu
[ 0.111199] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.111317] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.113854] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.114730] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.172691] mxs-dma 1804000.dma-apbh: initialized
[ 0.175768] soc_in: supplied by +V3.3
[ 0.178880] VCC_USB[1-4]: supplied by 5V
[ 0.181888] SCSI subsystem initialized
[ 0.182613] usbcore: registered new interface driver usbfs
[ 0.182854] usbcore: registered new interface driver hub
[ 0.183165] usbcore: registered new device driver usb
[ 0.185709] i2c i2c-0: IMX I2C adapter registered
[ 0.185807] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.187268] i2c i2c-1: IMX I2C adapter registered
[ 0.187362] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.187817] Linux video capture interface: v2.00
[ 0.187989] pps_core: LinuxPPS API ver. 1 registered
[ 0.188049] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.188195] PTP clock support registered
[ 0.188985] Advanced Linux Sound Architecture Driver Initialized.
[ 0.191976] clocksource: Switched to clocksource mxc_timer1
[ 0.192307] VFS: Disk quotas dquot_6.6.0
[ 0.192504] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.218060] NET: Registered protocol family 2
[ 0.219523] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.219709] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.219912] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.220079] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.220183] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.220559] NET: Registered protocol family 1
[ 0.221576] RPC: Registered named UNIX socket transport module.
[ 0.221660] RPC: Registered udp transport module.
[ 0.221714] RPC: Registered tcp transport module.
[ 0.221766] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.227038] Bus freq driver module loaded
[ 0.230897] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.248999] NFS: Registering the id_resolver key type
[ 0.249135] Key type id_resolver registered
[ 0.249195] Key type id_legacy registered
[ 0.249267] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.250824] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.251755] fuse init (API version 7.26)
[ 0.269462] io scheduler noop registered
[ 0.269546] io scheduler deadline registered
[ 0.270037] io scheduler cfq registered (default)
[ 0.274254] backlight supply power not found, using dummy regulator
[ 0.278087] 21c8000.lcdif supply lcd not found, using dummy regulator
[ 0.278633] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.390459] Console: switching to colour frame buffer device 80x30
[ 0.410411] mxsfb 21c8000.lcdif: initialized
[ 0.416834] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.430264] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
[ 1.074591] console [ttymxc0] enabled
[ 1.083895] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 63, base_baud = 5000000) is a IMX
[ 1.101294] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 64, base_baud = 5000000) is a IMX
[ 1.137958] loop: module loaded
[ 1.154576] random: fast init done
[ 1.165339] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.175631] nand: Macronix MX30LF4G28AC
[ 1.183310] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 1.199466] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 1.210729] Bad block table found at page 262080, version 0x01
[ 1.221381] Bad block table found at page 262016, version 0x01
[ 1.232461] 5 ofpart partitions found on MTD device gpmi-nand
[ 1.242398] Creating 5 MTD partitions on "gpmi-nand":
[ 1.251623] 0x000000000000-0x000000080000 : "mx6ull-bcb"
[ 1.262363] 0x000000080000-0x000000200000 : "u-boot1"
[ 1.272501] 0x000000200000-0x000000380000 : "u-boot2"
[ 1.282508] 0x000000380000-0x000000400000 : "u-boot-env"
[ 1.292705] 0x000000400000-0x000020000000 : "ubi"
[ 1.314133] gpmi-nand 1806000.gpmi-nand: driver registered.
[ 1.328144] spi_imx 2008000.ecspi: probed
[ 1.337715] libphy: Fixed MDIO Bus: probed
[ 1.348192] 20b4000.ethernet supply phy not found, using dummy regulator
[ 1.359928] pps pps0: new PPS source ptp0
[ 1.370076] libphy: fec_enet_mii_bus: probed
[ 1.381235] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.393129] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.403331] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.412715] usbcore: registered new interface driver usb-storage
[ 1.422814] usbcore: registered new interface driver usbserial
[ 1.432416] usbcore: registered new interface driver usbserial_generic
[ 1.442510] usbserial: USB Serial support registered for generic
[ 1.452030] usbcore: registered new interface driver ftdi_sio
[ 1.461135] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.475030] usbcore: registered new interface driver pl2303
[ 1.484178] usbserial: USB Serial support registered for pl2303
[ 1.496118] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.517036] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.525821] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.562056] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.573620] hub 1-0:1.0: USB hub found
[ 1.581334] hub 1-0:1.0: 1 port detected
[ 1.592076] mousedev: PS/2 mouse device common for all mice
[ 1.608494] input: AD7879 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-002c/input/input0
[ 1.633870] rtc-ds1307 0-0068: rtc core: registered m41t0 as rtc0
[ 1.645704] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.662804] i2c /dev entries driver
[ 1.675271] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.686901] sdhci: Secure Digital Host Controller Interface driver
[ 1.697265] sdhci: Copyright(c) Pierre Ossman
[ 1.705727] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.718719] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 1.792478] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.872042] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 1.903445] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.913863] usbcore: registered new interface driver usbhid
[ 1.923823] usbhid: USB HID core driver
[ 1.938020] Netfilter messages via NETLINK v0.30.
[ 1.947482] nfnl_acct: registering with nfnetlink.
[ 1.957008] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 1.968107] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 1.979549] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.990490] NET: Registered protocol family 10
[ 2.002097] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.011728] NET: Registered protocol family 17
[ 2.020577] Bridge firewalling registered
[ 2.028905] 8021q: 802.1Q VLAN Support v1.8
[ 2.037284] Key type dns_resolver registered
[ 2.048890] cpu cpu0: Registered imx6q-cpufreq
[ 2.082288] Registering SWP/SWPB emulation handler
[ 2.090054] registered taskstats version 1
[ 2.124897] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.131729] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.202017] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.232344] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.249741] hub 2-0:1.0: USB hub found
[ 2.261722] hub 2-0:1.0: 1 port detected
[ 2.269828] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:115C passive:95C
[ 2.285310] ubi0: default fastmap pool size: 200
[ 2.291760] ubi0: default fastmap WL pool size: 100
[ 2.298470] ubi0: attaching mtd4
[ 2.436061] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 2.447518] scsi host0: usb-storage 1-1:1.0
[ 2.674390] ubi0: attached by fastmap
[ 2.685138] ubi0: fastmap pool size: 200
[ 2.695980] ubi0: fastmap WL pool size: 100
[ 2.728614] ubi0: attached mtd4 (name "ubi", size 508 MiB)
[ 2.735975] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.744647] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.753207] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.761963] ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
[ 2.769840] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 2.780672] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2099907239
[ 2.793618] ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
[ 2.806968] ubi0: background thread "ubi_bgt0d" started, PID 109
[ 2.819213] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 2.830297] rtc-ds1307 0-0068: setting system clock to 2019-01-15 13:21:15 UTC (1547558475)
[ 2.843691] soc_in: disabling
[ 2.848707] ALSA device list:
[ 2.853728] No soundcards found.
[ 2.861726] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 110
[ 3.083056] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs"
[ 3.106818] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.133925] UBIFS (ubi0:3): FS size: 493936640 bytes (471 MiB, 3890 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.162808] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 3.177947] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID A968AC11-6EE8-4E2E-90DD-3C4553C1D51F, small LPT model
[ 3.212468] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 3.225828] devtmpfs: mounted
[ 3.232642] Freeing unused kernel memory: 1024K
[ 3.524323] scsi 0:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[ 3.549061] sd 0:0:0:0: [sda] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 3.565435] sd 0:0:0:0: [sda] Write Protect is off
[ 3.574101] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.600764] sda: sda1 sda2
[ 3.611819] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.025961] random: crng init done
[ 4.465829] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 4.517980] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2017.12!
[ 4.578059] systemd[1]: Set hostname to <colibri-imx6ull>.
[ 5.330897] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 5.342021] mmc1: error -22 whilst initialising SDIO card
[ 5.434419] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 5.444485] mmc1: error -22 whilst initialising SDIO card
[ 6.387833] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 6.437402] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 6.482939] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 6.533653] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 6.559099] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 6.570268] mmc1: error -22 whilst initialising SDIO card
[ 6.587181] systemd[1]: Mounting Kernel Debug File System...
[ 6.635473] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 6.669574] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 6.678511] mmc1: error -22 whilst initialising SDIO card
[ 6.693883] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Reached target Remote File Systems.
[ 6.760457] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 6.769395] mmc1: error -22 whilst initialising SDIO card
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ 6.853671] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 6.862561] mmc1: error -22 whilst initialising SDIO card
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on Journal Socket.
Starting Journal Service...
Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
Starting Create list of required st��������ce nodes for the current kernel...
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
[ OK ] Mounted Temporary Directory (/tmp).
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Journal Service.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Apply Kernel Variables.
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ 8.003197] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 8.012141] mmc1: error -22 whilst initialising SDIO card
[ OK ] Started Create Static Device Nodes in /dev.
[ 8.114478] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 8.125486] mmc1: error -22 whilst initialising SDIO card
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ 8.231699] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 8.240637] mmc1: error -22 whilst initialising SDIO card
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ 8.356174] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 8.365113] mmc1: error -22 whilst initialising SDIO card
[ 8.632777] systemd-journald[125]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems.
Starting Load/Save Random Seed...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started udev Kernel Device Manager.
[ 9.529369] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 9.538337] mmc1: error -22 whilst initialising SDIO card
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Coldplug all Devices.
Starting Create Volatile Files and Directories...
[ 9.769339] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 9.778291] mmc1: error -22 whilst initialising SDIO card
[ 9.962411] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 9.971287] mmc1: error -22 whilst initialising SDIO card
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ 10.147301] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 10.156298] mmc1: error -22 whilst initialising SDIO card
Starting Network Time Synchronization...
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight��…ightness of backlight:backlight...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttymxc0.
[ 10.836276] CAN device driver interface
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target[ 11.025201] mcp251x spi0.0: Cannot initialize MCP2515. Wrong wiring?
System Initialization.
Starting sshd.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 11.091169] mcp251x spi0.0: Probe failed, err=19
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Reached target System Time Synchronized.
[ 11.443286] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 11.452282] mmc1: error -22 whilst initialising SDIO card
[ OK ] Listening on sshd.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 11.656825] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 11.665863] mmc1: error -22 whilst initialising SDIO card
Starting RPC Bind Service...
[ OK ] Started Timestamping service.
[ OK ] Started D-Bus System Message Bus.
[ 11.940501] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 11.949507] mmc1: error -22 whilst initialising SDIO card
