I’m currently trying to get the Free RTOS hello_world.elf example running. For this I tried deployment over the linux and did the following
root@colibri-imx7:~# ubiupdatevol /dev/ubi0_2 hello_world.elf
Colibri iMX7 # setenv m4boot 'ubi read ${loadaddr} m4firmware && bootaux ${loadaddr}'
Colibri iMX7 # saveenv
After the reboot I got the expected boot log on UART_A that Free RTOS was booted:
Read 0 bytes from volume m4firmware to 80800000
No size specified -> Using max size (87677)
## Starting auxiliary core at 0x1F0002E1 ...
Read 0 bytes from volume kernel to 81000000
No size specified -> Using max size (5114608)
Read 0 bytes from volume dtb to 82000000
No size specified -> Using max size (45016)
After I didn’t get any output from the UART_B I added the following boot options:
Colibri iMX7 # setenv defargs clk_ignore_unused
Colibri iMX7 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt rm /soc/aips-bus@30800000/spba-bus@30800000/serial@30890000'
Still nothing on UART_B. Also attached the cable on UART_A to make sure there is no issue with the cable.
Here is log of “printenv” in the boot loader. I also checked that the options were saved.
printenv log
