Hello Toradex,
After upgrading to the latest bsp v2.6B1 it seems like we’re missing half of the module ram. The following output is shown in u-boot:
U-Boot 2015.04+fslc+ge1a48b2 (Apr 19 2016 - 15:47:44)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
CPU: Temperature 56 C
Reset cause: WDOG
I2C: ready
DRAM: 256 MiB
PMIC: device id: 0x10, revision id: 0x11
PMIC: programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB IT V1.0B, Serial# 04859743
Net: using PHY at 0
FEC [PRIME]
Normal Boot
What are the steps required to get RAM configuration back to the correct settings? We already tried creating a new configblock. We builded the image using Bitbake (Toradex Console Image).
From U-boot, try entering the following command:
patch_ddr_size
Let me know if that command resolves the issue or not. We will begin investigating possible causes of this problem.
max.tx
April 20, 2016, 5:27pm
3
Is this easily testable in an open embedded environment?
I don’t know how and which recipe exactly i need to patch to test this. There are multiple u-boot directories in the stuff folder.
max.tx
April 21, 2016, 8:08am
5
Hi
I pushed changed recipes to the V2.6-next branch of meta-toradex. You could use them to find the relevant changes or cherry-pick them into your branch.
commit
Javier
June 14, 2016, 8:01am
6
we patched the Model: Toradex Colibri iMX6 DualLite 512MB V1.0A like this:
Colibri iMX6 # patch_ddr_size
done.
But we still have only 244MB
root@christ:~# free -m
total used free shared buffers cached
Mem: 244 193 50 5 11 52
-/+ buffers/cache: 129 114
Swap: 0 0 0
What should we do?
Javier
max.tx
June 14, 2016, 6:28pm
7
Hi Javier
You have to rebuild U-Boot with sources that include above mentioned patch and then run patch_ddr_size.
Regards
Max
I applied the patch, but the problem persisted.
Used a recent commit to confirm.
U-boot 2015.04 and kernel 3.14.52.
COMMIT: b66337d357cca761bf8627acbb1ec991f425f0b4
With PATCH: u-boot-toradex.git - U-Boot bootloader for Apalis and Colibri modules
U-Boot 2015.04+fslc+gb66337d (Jul 20 2016 - 10:25:32)
CPU: Freescale i.MX6DL rev1.2 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 256 MiB
PMIC: programmed
Using COMMIT: u-boot-toradex.git - U-Boot bootloader for Apalis and Colibri modules
U-Boot 2015.04+fslc+g59091f0 (Jul 20 2016 - 10:11:52)
CPU: Temperature 41 C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
PMIC: programmed
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.0A, Serial# 04869737
Net: using PHY at 0
FEC [PRIME]
Normal Boot
Colibri iMX6 #
Both recompiled and recorded in /dev/mmcblk0boot0.
Cleiton Bueno
Blog | Linkedin | B2Open
max.tx
July 20, 2016, 3:51pm
9
What happens if you execute in U-Boot
patch_ddr_size
reset
If it still shows 256MB try this, which makes sure the eMMC boot mode is set to the first boot partition:
mmc partconf 0 1 1 0
reset
Note that your first U-Boot console output does not match the U-Boot commit you claim it is in your commit.
@max.tx Yeah, it worked!
Reset cause: WDOG
I2C: ready
DRAM: 256 MiB
PMIC: programmed
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.0A, Serial# 04869730
Net: using PHY at 0
FEC [PRIME]
Colibri iMX6 #
Colibri iMX6 #
Colibri iMX6 #
Colibri iMX6 #
Colibri iMX6 #
patched, done.
Colibri iMX6 # reset
resetting ...
U-Boot 2015.04+fslc+gb66337d (Jul 02 2016 - 08:42:00)
Reset cause: WDOG
I2C: ready
DRAM: 512 MiB
PMIC: programmed
In: serial
Out: serial
Err: serial
Net: using PHY at 0
FEC [PRIME]
