i’m working with the following configuration:
Apalis iMX8QM 4GB WB IT V1.1D
Ixora Carrier Board V 1.2A
Linux BSP 6.3.0
I would like to improve the ability to load video via MIPI CSI-2.
When you run the MIPI CSI-2 driver, a capture sub device is created, but /dev/videoX is not created.
However, when I tried to play it with gstreamer, it stopped in the following state:
# gst-launch-1.0 v4l2src device=/dev/video2 ! autovideosink
[ 1337.132101] usb 3-1.2: reset high-speed USB device number 4 using ci_hdrc
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Hi @sjjin , I’m still not convinced that the driver is properly recognized. How did you add the TP2855 driver? Can you share the device tree and kernel config?
Well, the TP2855 is there according to the Kernel configuration. Do you have any information or reference on how this was added? This is not in our default BSP and I couldn’t find any information in Google about a Linux driver.
I could see 6 video devices (video0-5) so I understand that this is not a problem anymore. Do you get the same response.
Checking the NXP Linux User Guide for 5.15 (Used in BSP 6.3.0), this is the correct Gstreamer pipeline for a TV decoder however, I don’t think this is your usecase. Have you tried any other pipelines for Webcam preview like the following?
Permissions are limited, but you can find it on the NXP Community:
You are right.
I also tried other pipelines.
# gst-launch-1.0 v4l2src device=/dev/video2 ! 'video/x-raw, format=(string)UYVY,width=1920,height=1080,framerate=(fraction)30/1' ! autovideosink
[ 1835.096744] usb 3-1.2: reset high-speed USB device number 3 using ci_hdrc
Also, pls check the output for gst-inspect-1.0 v4l2src
Hi @sjjin , thanks for all the information. Based on the logs, I think you have a USB/UVC camera. Does Gstreamer work for this USB camera? That should be very straightforward.
Kindly confirm.
The TP2855 seems to be correctly identified so my suspicion is with the Gstreamer pipeline. Let’s confirm that the USB camera is working.
I got USB/UVC information using v4l2-ctl --list-devices:
UVC Camera (046d:0825) (usb-ci_hdrc.1-1.2):
/dev/video5
/dev/video6
/dev/media2
The video was confirmed normally when played with gstreamer.
# gst-launch-1.0 v4l2src device=/dev/video5 ! autovideosink
[ 211.928876] usb 3-1.2: reset high-speed USB device number 3 using ci_hdrc
Redistribute latency...
0:00:04.4 / 99:99:99.
Do you have any additional requests for debugging?
