Marvell SDIO8787 Driver Support
We are looking at implementing Marvell SD8787 on Apalis T30 with WEC7. Has this configuration been tested? Is there plans to fix this issue?
10584 Known Issue SDIO8787 WiFi Driver Does Not Work on Colibri T30 / WEC2013 Colibri T30 SDIO/SD/MMC WEC2013
Description: It’s not clear if the problem is related to the Wifi driver, the SDIO driver or anything else.
Hi, I have a similar problem. Did you solve it? Thanks.
We currently don’t know where the driver fails. We planned to work on the issue 10584 and get a solution until beginning of July. We will ad some updates to this community question as soon as we have some news.
