hardware and base software
I use dahlia v1.1C + verdin.
I installed the official release of the standard image. Verdin-iMX8MP_Reference-Multimedia-Image-Tezi_6.3.0+build.7.
# cat /etc/os-release
ID=tdx-xwayland
NAME="TDX Wayland with XWayland"
VERSION="6.3.0+build.7 (kirkstone)"
VERSION_ID=6.3.0-build.7
PRETTY_NAME="TDX Wayland with XWayland 6.3.0+build.7 (kirkstone)"
DISTRO_CODENAME="kirkstone"
My purpose
I need to add my own peripheral module and compile it into the Image. For the first step, I want to compile a standard image and successfully replace it. However, I encountered a failure in this step.
My operation
I downloaded the code for the kernel using the following command. Then, I followed this article to compile it and obtained the Image.gz and modules.
git clone -b toradex_5.15-2.1.x-imx git://git.toradex.com/linux-toradex.git linux --depth 1
git clone -b toradex_5.15-2.1.x-imx git://git.toradex.com/device-tree-overlays.git device-trees --depth 1
The problems encountered
I successfully replaced the Image and modules into the current board. However, the system encountered the following error during startup.
[ OK ] Started Serial Getty on ttymxc2.
[ OK ] Reached target Login Prompts.
[FAILED] Failed to start User Login Management.
See 'systemctl status systemd-logind.service' for details.
[ OK ] Reached target Multi-User System.
Starting Weston, a Wayland…ositor, as a system service...
Feb 23 05:53:50 verdin-imx8mp-14773666 authpriv.info systemd: pam_unix(weston-autologin:session): session opened for user root(uid=0) by (uid=0)
[ OK ] Stopped BlueALSA service.
[FAILED] Failed to start BlueALSA service.
See 'systemctl status bluealsa.service' for details.
[ OK ] Stopped User Login Management.
Starting Load Kernel Module drm...
Starting User Database Manager...
[ OK ] Finished Load Kernel Module drm.
[ OK ] Started User Database Manager.
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See 'systemctl status weston.service' for details.
[ OK ] Reached target Graphical Interface.
[FAILED] Failed to start Load Kernel Module drm.
See 'systemctl status modprobe@drm.service' for details.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
My assumptions and requests.
I noticed that the downloaded image used the aarch64-tdx-linux-gcc compiler, which is different from the one mentioned in the article. Is this related to the issue? Can you provide some guidance?
