Colibri iMX6DL 512MB IT v1.1b
Colibri Evaluation Board
TorizonCore Upstream 5.6.0dev…202202+build21
Seems like when I build my application with F5, I get:
> Executing task: make WORKDIR=/workspaces/EmeraBlockEnergyBox/appconfig_0/work/EmeraBlockEnergyBox install <
make: Warning: File 'EmeraBlockEnergyBox' has modification time 0.88 s in the future
installing...
mkdir -p /workspaces/EmeraBlockEnergyBox/appconfig_0/work/EmeraBlockEnergyBox
cp EmeraBlockEnergyBox /workspaces/EmeraBlockEnergyBox/appconfig_0/work/EmeraBlockEnergyBox/
done.
Terminal will be reused by tasks, press any key to close it.
but if I run F1 → Torizon: build release container for this application: I get:
arm-linux-gnueabihf-gcc -o EmeraBlockEnergyBox EmeraBlockEnergyBox.o
/usr/lib/gcc-cross/arm-linux-gnueabihf/10/../../../../arm-linux-gnueabihf/bin/ld: EmeraBlockEnergyBox.o: in function `InputGPIO':
EmeraBlockEnergyBox.c:(.text+0x407be): undefined reference to `gpiod_ctxless_get_value'
/usr/lib/gcc-cross/arm-linux-gnueabihf/10/../../../../arm-linux-gnueabihf/bin/ld: EmeraBlockEnergyBox.o: in function `OutputGPIO':
EmeraBlockEnergyBox.c:(.text+0x4080c): undefined reference to `gpiod_ctxless_set_value'
collect2: error: ld returned 1 exit status
make: *** [Makefile:31: EmeraBlockEnergyBox] Error 1
The terminal process "/bin/bash '-c', 'make WORKDIR=/workspaces/EmeraBlockEnergyBox/appconfig_0/work/EmeraBlockEnergyBox install'" failed to launch (exit code: 2).
As I recall, I needed to install dev packages:
libgpiod-dev:armhf
which was a run-time library which needed to be present on my device.
Is it possible I need to apt-get this into Ubuntu as well in WSL?
