Dear all/ @marcel.tx
I am using Apalis T30 module version 1.0 E on Ixora carrier board v1.0A.
I have successfully compiled mainline kernel 4.18.11 and I am quite happy with the result as I have everything working as I expected.
I need to connect a NRF24L01+ radio modul using the SPI however, I do not see any SPI device in /dev/spi*
I double checked the “tegra30-apalis-eval.dts” device tree and it seems that the spidev are already enabled.
/* SPI1: Apalis SPI1 */
spi@7000d400 {
spi-max-frequency = <25000000>;
spidev0: spidev@1 {
compatible = "spidev";
reg = <1>;
/* SPI5: Apalis SPI2 */
spi@7000dc00 {
spidev1: spidev@2 {
reg = <2>;
Can you please advise if this can be done and I can use mainline kernel on Apalis T30 and connect a SPI module to that?
I appreciate your helps…
Most likely you do not have the user space SPI dev driver enabled in your kernel configuration. Otherwise, please do post the full serial console boot-up log as a textual file for us to have a look at.
Dear @marcel.tx ,
As always, you were right. I have enabled that option in Kernel and I can see the SPI devices now.
While I am in this post, may I kindly ask you to advise me for a question regarding to the same mater?
Now that I have the SPI devices,I plan to connect my SPI module (NRF24L01+) to pin numbers as per Ixora X27 header:
8 -> SPI1_CLK
9 -> SPI1_CS
10 -> SPI1_MISO
11 -> SSP_MOSI
May I kindly ask you to advise if that is correct and also kindly tell me what will be the GPIO number for Apalis T30 if I want to set the pin number inside my application (MySensors Library) to recognize the SPI module?
As always, you were right. I have enabled that option in Kernel and I can see the SPI devices now. While I am in this post, may I kindly ask you to advise me for a question regarding to the same mater?
Sure.
Now that I have the SPI devices,I plan to connect my SPI module (NRF24L01+) to pin number as per Ixora X27 header:
8 -> SPI1_CLK
9 -> SPI1_CS
10 -> SPI1_MISO
11 -> SSP_MOSI
Yes, that looks about right.
I don’t think any GPIO number is required (what for anyway?) as /dev/spi0 will directly talk to your device hooked up to Apalis SPI1 incl. asserting its chip select SPI1_CS.
@marcel.tx
The library needs to be compiled for specific board.
For instance I have added these lines to enable the pins for Tegra as it shows it has a sample pin for Raspberry Pi:
#if defined(LINUX_ARCH_TEGRA)
// Default to Tegra, Apalis T30
const uint8_t SS = 9;
const uint8_t MOSI = 11;
const uint8_t MISO = 10;
const uint8_t SCK = 8;
#else
// Default to Raspberry Pi
const uint8_t SS = 24;
const uint8_t MOSI = 19;
const uint8_t MISO = 21;
const uint8_t SCK = 23;
#endif
The pin for RPi, (24,19,21,23) correspond to the physical pin on RPi header.
I have to do the same for Tegra configuration which I have added above to be able to compile the app properly.
However, I am struggling adding the right GPIO number…
Thats the place I need to configure
The library needs to be compiled for specific board. For instance I have added these lines to enable the pins for Tegra as it shows it has a sample pin for Raspberry Pi:
Not sure what exactly you are talking about, sorry.
The pin for RPi, (24,19,21,23) correspond to the physical pin on RPi header. I have to do the same for Tegra configuration which I have added above to be able to compile the app properly. However, I am struggling adding the right GPIO number… Thats the place I need to configure
For SPI usage I really don’t see why one would need to know any GPIO numbers unless it would not even use the in-kernel driver but rather do some kind of user space bit-banging.
The only related thing I could think of is e.g. libsoc where our boards recently got added which allows you directly using MXM3 resp. SODIMM pin numbers:
I don’t know how to explain. I only need to directly communicate via GPIO pins on header X27.
I just need to know what will be the proper GPIO pin number for MOSI, MISO, SC and SCK pins…
That is usually a good indication of the whole approach being flawed.
But communicate what? What for? Didn’t you want to do SPI? What should that have to do with GPIOs?
Well, the regular MXM3 resp. SODIMM pin to in-kernel GPIO number mapping may be found here:
@marcel.tx ,
Let say an example:
GPIO3 , Physical pin 15 on Ixora is : GPIO 148 in sysfs for Apalis T30
What would be for these?
8 -> SPI1_CLK
9 -> SPI1_CS
10 -> SPI1_MISO
11 -> SSP_MOSI
Finally I found it myself.
For every one else want to know , here is the way to find the proper GPIO number for physical Pin on X27 (Ixora):
Example: What is Linux Pin number to control if Ixora GPIO Pin no is 15
apalis_arm_ixora_datasheet
Page: 30 -> 3.16. Extension Header (X27)
15 ==> GPIO3
Then we go to : apalis_t30_datasheet
Page: 13 -> Table 3-1 X1 Connector
GPIO3 (Apalis Signal Name) ==> 5 (X1)
Then:
Page: 21
5 (X1 pin) -> GPIO-S.04 (GPIO) ==> Which will be: S4
Then:
URL: https://developer.toradex.com/knowledge-base/gpio-alphanumeric-to-gpio-numeric-assignment#T20_T30_TK1
"S4" in "GPIO" column will be : 148 in "Numeric Representation" column
To control that pin (148 -> Physical pin 15):
# echo 148 > /sys/class/gpio/export
# echo out > /sys/class/gpio/gpio148/direction
# echo 1 > /sys/class/gpio/gpio148/value
# echo 0 > /sys/class/gpio/gpio148/value
Therefore:
Physical 8 --> 221 (X1): SPI1_SCK ---> 189
Physical 9 --> 227 (X1): SPI1_SS ---> 190
Physical 10 --> 223 (X1): SPI1_MISO ---> 191
Physical 11 -> 225 (X1): SPI1_MOSI ---> 188
