Hi there,
I’ve trying to build the m4ctrl application and kernel module according to the indications here without success.
Basically, I first used openEmbedded to get a Linux image for the Colibri iMX8QXP (dunfell). I configured the compilation environment variables to:
- SOC=IMX8QXP
- ARCH=arm64
- KDIR=~/oe-core/build/tmp/work/colibri_imx8x-tdx-linux/linux-toradex/5.4.154+gitAUTOINC+c65f162295-r0/build/
- CROSS_COMPILE=gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
Then, I run make and get the error:
make[2]: Entering directory ‘/home/ebers/oe-core/build/tmp/work/colibri_imx8x-tdx-linux/linux-toradex/5.4.154+gitAUTOINC+c65f162295-r0/build’
CC [M] /home/ebers/repo/m4ctrl/kernel/m4ctrl_dev.o
/home/ebers/repo/m4ctrl/kernel/m4ctrl_dev.c:18:10: fatal error: soc/imx8/sc/sci.h: No such file or directory
18 | #include <soc/imx8/sc/sci.h>
Has anyone tried getting this module for this specific configuration?
Any help is appreciated.
Víctor
