I need help with setting up lpspi0 in “toradex,colibri-imx8qxp-eval-v3”. I can see /dev/spidev0.0 but I could not get any signals in the clock line SC_P_SAI0_TXFS_ADMA_SPI1_SCK - SODIMM PIN 101 when executing echo 1 > /dev/spidev0.0. Please let me know if I miss anything.
It works well on the other SPI devices (SPI2 /dev/spidev1.0 and SPI3 /dev/spidev2.0)
There are no changes made in build/workspace/sources/linux-toradex/scripts/dtc/include-prefixes/arm64/freescale/fsl-imx8dx.dtsi for lpspi0.
root@colibri-imx8x:~# find / -name
spidev0.0 /dev/spidev0.0
/sys/class/spidev/spidev0.0
/sys/devices/platform/5a000000.lpspi/spi_master/spi0/spi0.0/spidev/spidev0.0
&lpspi0 {
#address-cells = <1>;
#size-cells = <0>;
fsl,spi-num-chipselects = <1>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lpspi0>;
cs-gpios = <
&gpio3 3 GPIO_ACTIVE_LOW
spidev1: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <10000000>;
/* Colibri SPI */
pinctrl_lpspi0: lpspi0 {
fsl,pins = <
SC_P_CSI_RESET_LSIO_GPIO3_IO03 0x21 /* SODIMM 29 */
SC_P_SAI0_TXD_ADMA_SPI1_SDO 0x06000040 /* SODIMM 103 */
SC_P_CSI_EN_ADMA_SPI1_SDI 0x06000040 /* SODIMM 37 */
SC_P_SAI0_TXFS_ADMA_SPI1_SCK 0x06000040 /* SODIMM 101 */
pinctrl_lpspi2: lpspi2 {
fsl,pins = <
SC_P_SPI2_CS0_LSIO_GPIO1_IO00 0x21 /* SODIMM 86 */
SC_P_SPI2_SDO_ADMA_SPI2_SDO 0x06000040 /* SODIMM 92 */
SC_P_SPI2_SDI_ADMA_SPI2_SDI 0x06000040 /* SODIMM 90 */
SC_P_SPI2_SCK_ADMA_SPI2_SCK 0x06000040 /* SODIMM 88 */
pinctrl_lpspi3: lpspi3 {
fsl,pins = <
SC_P_SPI3_CS0_LSIO_GPIO0_IO16 0x21 /* SODIMM 68 */
SC_P_SPI3_CS1_ADMA_LCDIF_D16 0x21 /* SODIMM 57 */
SC_P_SPI3_SDO_ADMA_SPI3_SDO 0x06000040 /* SODIMM 66 */
SC_P_SPI3_SDI_ADMA_SPI3_SDI 0x06000040 /* SODIMM 64 */
SC_P_SPI3_SCK_ADMA_SPI3_SCK 0x06000040 /* SODIMM 54 */
