Lot of host-user-contaminated warnings when building the image using “bitbake -k angstrom-lxde-image”. Is this cause any problem to the image building or future work??
No, this should not usually cause any subsequent issues. But what exact hardware and software versions of things are you actually taking about?
Hi
No, it does not have negative effects to the artifacts created.
It is caused by this patch not (yet) being applied by the meta-angstrom layer.
That’s why we do disable the warning in the local.conf template.
Max
