I got my iMX6 and Viola carrier board hooked up and running. I was able to use the pre-installed EasyInstaller to select an image and install it. After restarting though, no display was visible through the HDMI port. Connecting to the UART port showed that the image was being loaded. Using a WinCE image there was no output beyond the image being started, with a Linux image I could use the UART to login, but not through the locally connected keyboard/mouse and display. I was using the Toradex provided images.
Using recovery mode I can revert to the EasyInstaller and once again the local display works. Is there a step I’m missing?
