Local C++ debugging stop working in the last VS code update
after build-debug-local task, no debug initiated and the debug terminal says
cppdbg: mitest:
&“aviso: GDB: Failed to set controlling terminal: Operaci\303\263n no permitida\n”
Version: 1.120.0
Commit: 0958016b2af9f09bb4257e0df4a95e2f90590f9f
Date: 2026-05-12T20:17:22Z
Electron: 39.8.8
ElectronBuildId: 13870025
Chromium: 142.0.7444.265
Node.js: 22.22.1
V8: 14.2.231.22-electron.0
OS: Linux x64 6.17.0-23-generic
Identifier: toradex.apollox-vscode
Version: 3.4.2
Last Updated: 1 week ago
Based on the error message you’re encountering, this appears to be a terminal control issue with GDB in the latest VS Code update. The error “Failed to set controlling terminal: Operación no permitida” suggests a permission or terminal handling problem.
To help troubleshoot this C++ debugging issue effectively, I need to clarify your setup:
Could you please specify:
  • Which Toradex hardware are you using? (e.g., Verdin iMX8M Plus, Apalis iMX8, Colibri iMX8X)
  • Which OS and version are you running on the device? (e.g., Torizon OS 6.8.2, BSP 7.2.0)
You can get this information by running the tdx-info command on your device. More details are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Common platforms to mention:
  • Hardware: Verdin iMX8M Plus, Verdin AM62, Aquila AM69, Apalis iMX8QP, Colibri iMX8X
  • OS: Torizon OS 6, Torizon OS 7.2.0-build.13, BSP 7, BSP 6
This information will help me provide the most accurate debugging guidance for your specific platform configuration.
is a problem downloading all separate debug info for /lib/x86_64-linux-gnu/libQt6, disconnect internet at start debug process and worked
Great finding! You’ve identified that the issue is related to GDB attempting to download debug symbols for Qt6 libraries during the debugging process. This is a common issue with recent VS Code updates when debugging applications that use Qt libraries.
Solution
Based on your discovery, here are the recommended approaches to resolve this debugging issue:
1. Disable Automatic Debug Symbol Downloads
Add the following GDB commands to your VS Code debugging configuration in .vscode/launch.json:
"setupCommands": [
        "description": "Disable automatic debug symbol downloads",
        "text": "-gdb-set auto-load safe-path /",
        "ignoreFailures": true
        "description": "Disable debuginfod",
        "text": "-gdb-set debuginfod enabled off",
        "description": "Enable pretty-printing for gdb",
        "text": "-enable-pretty-printing",
2. Environment Variable Approach
Set the DEBUGINFOD_URLS environment variable to disable automatic downloads. Add this to your debugging configuration:
"environment": [
        "name": "DEBUGINFOD_URLS",
        "value": ""
3. GDB Configuration File
Create a .gdbinit file in your project root with:
Why This Happens
Recent GDB versions automatically attempt to download debug symbols from online repositories when debugging applications that link against system libraries like Qt6. This can cause delays and terminal control issues during local debugging sessions.
Your workaround of disconnecting the internet confirms this is the root cause, as it prevents GDB from attempting these downloads.
Additional Considerations
For Torizon-based applications, this issue typically affects local debugging more than remote debugging, since the containerized environment on the target device usually has a more controlled symbol environment (1).
the suggested fixes don’t work, the only solution worked is disconnects internet
found a solution, in .vscode/settings.json add:
“terminal.integrated.env.linux”: {
“DEBUGINFOD_URLS”: “”,
“DEBUGINFOD_TIMEOUT”: “1”
