Loading easy installer gets stuck at step 3 - SDPV: jump
Trying to load easy installer gets stuck at step 3:
Greetings @klaus_zahn,
Before we can investigate what version of the Verdin i.MX8MM are you using? Also what is the version of Easy Installer you are trying to load?
Hi @jeremias.tx
I added a picture of the verdin board - is that ok for the version.
The version of the Easy Installer is: Verdin-iMX8MM_ToradexEasyInstaller_5.3.0+build.3
(in fact I try several of the most recent builds)
Hi @klaus_zahn,
Ah yes the hardware version is the issue here, Version 1.0 Verdin i.MX8MM is considered last generation hardware and is no longer supported by our latest software including Toradex Easy Installer.
If you want to we still have older releases of Toradex Easy Installer that should still be compatible with this older hardware: https://artifacts.toradex.com/artifactory/tezi-oe-prod-frankfurt/thud/release/4/verdin-imx8mm/tezi/tezi-run/oedeploy/Verdin-iMX8MM_ToradexEasyInstaller_2.0b7-20210415.zip
Furthermore as a side-note when installing an OS image please stick to 5.1.0 version software if you want full functionality. The newer 5.3.0 releases don’t guarantee full feature functionality with the last generation hardware.
For more information on this hardware change please review this article: https://developer.toradex.com/verdin-sample-phase-over
