I’m using LM816 USB WiFi dongle with my board. I have installed the driver of LM006 and I do not have any problem with connection to WiFi network but when I tried to use it for Internet Radio data streaming I’m getting wrong data from time to time (not reported as a transmission error). Do you have any suggestion what to do to get better result? Should I change the driver or so?
Could you specify what exactly “wrong data” is detected? Please be aware that LM816 antenna it weak, so you need to have a WiFi router to be close enough to your board.
