Linking 32 bit .o file in Verdin iMX8M Mini
Hi Costa,
I would like know Torizon OS 32bit is available for IMX8M mini? and I am trying run using task runner with run-container-torizon-release-arm64.
My docker file contains:
build ------------------------------------------------------------------------
FROM commontorizon/debian-cross-toolchain-${IMAGE_ARCH}:${CROSS_SDK_BASE_TAG} AS build
ARG APP_ROOT
ARG IMAGE_ARCH=aarch64
RUN dpkg --add-architecture armhf &&
apt-get update &&
apt-get install -y --no-install-recommends
libc6:armhf
libstdc++6:armhf
libgcc-s1:armhf
gcc-arm-linux-gnueabihf
g+±arm-linux-gnueabihf &&
apt-get clean && rm -rf /var/lib/apt/lists/*
#deps
RUN apt-get -q -y update &&
apt-get -q -y install
#DO NOT REMOVE THIS LABEL: this is used for VS Code automation
#torizon_packages_build_start
#torizon_packages_build_end
apt-get clean && apt-get autoremove &&
#deps
COPY ./includes ${APP_ROOT}
COPY . ${APP_ROOT}
USER root
WORKDIR ${APP_ROOT}
#Remove the code from the debug builds, inside this container, to build the
release version from a clean build
RUN rm -rf ${APP_ROOT}/build-${IMAGE_ARCH}
#Compile the application
RUN if [ “$IMAGE_ARCH” = “arm64” ] ; then
make ARCH=${IMAGE_ARCH} CC=aarch64-linux-gnu-g++ CXXFLAGS=“-DEC_ARCH=EC_ARCH_ARM64” ;
elif [ “$IMAGE_ARCH” = “arm” ] ; then
make ARCH=${IMAGE_ARCH} CC=arm-linux-gnueabihf-g++ ;
elif [ “$IMAGE_ARCH” = “amd64” ] ; then
make ARCH=${IMAGE_ARCH} CC=x86_64-linux-gnu-g++ ;
fi
deploy -----------------------------------------------------------------------
FROM --platform=linux/${IMAGE_ARCH} commontorizon/debian:${BASE_VERSION} AS deploy
ARG IMAGE_ARCH
ARG APP_ROOT
RUN apt-get -y update && apt-get install -y --no-install-recommends
#torizon_packages_prod_start
#torizon_packages_prod_end
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
in my makefile its like:
Compiler and flags
CC := g++
CCFLAGS := -I/includes -std=c++14
#CXXFLAGS := -DEC_ARCH=EC_ARCH_ARM64
DBGFLAGS := -g
LDFLAGS := -Lsrc/SDK/LIB/Linux/aarch32
-l:libMaster.a
-l:libRasSrv.a
libMaster.a 32bit library
libRasSrv.a 32bit library
Output:
-Lsrc/SDK/LIB/Linux/aarch32 -l:libMaster.a -l:libRasSrv.a
91.19 /usr/lib/gcc-cross/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible src/SDK/LIB/Linux/aarch32/libMaster.a when searching for -l:libMaster.a
91.19 /usr/lib/gcc-cross/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld: cannot find -l:libMaster.a: No such file or directory
91.19 /usr/lib/gcc-cross/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible src/SDK/LIB/Linux/aarch32/libRasSrv.a when searching for -l:libRasSrv.a
91.19 /usr/lib/gcc-cross/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld: cannot find -l:libRasSrv.a: No such file or directory
91.19 /usr/lib/gcc-cross/aarch64-linux-gnu/12/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible src/SDK/LIB/Linux/aarch64/libARasSrv.a when searching for -l:libRasSrv.a
How to compile this 32bit library?
