Light linux image for Totalcross GUI application
Hello everyone.
I’m new at embedded Linux. I would like to know how to customize a light image Linux for imx6ULL to run a GUI application developed by Totalcross. I saw that Toradex has some tutorials about customizing images but what are the minimum requirements to run a GUI application in iMX6ULL?
I’m using the following hardware:
  • Colibri iMX6ULL 512MB IT
  • Aster Carrier Board
Thanks for any help!
Charles Dias.
Hi @CharlesDias ,
Welcome to the Toradex community.
Please check this article to find the instructions on how to build a new image.
Since you want a GUI, the best option is use the tdx-reference-multimedia-image recipe as a starting point, then you can remove all the packages you won’t use and add your needed packages.
If you need more information about how to add the TotalCross into our image, please take a look at this article.
Daniel Morais
Hi Daniel.
Thanks for your tip! I’ll try!
Charles Dias
